Question about Compaq Computers & Internet
My laptop caompaq presario F700 has a small key hole next to power plug. I am told that this somehow has been lock and laptop is unable to power up. The screen is black no image and laptop does not power up but only for a few seconds and powers down. Has not been damage or droped. I tried ''F'' Keys nothing seems to work. How please can this problem be fix.
  • 408 Answers
Check your power adapter for juice with a multimeter.  Chances are the power cable is bad and your battery is dead.  That keyhold that you are talking about is a lock, but for the purpose of installing a cable lock so it can not be taken.  Most stores use these to prevent theft.
Posted on Mar 03, 2009
Not booting hp presario f700
hit the f5 key then follow the screen from there that is in safe mode
Mar 21, 2014 | HP Compaq Presario F500 F700 and G6000...
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like
Dec 29, 2012 | ASUS K52n-a1 Notebook
I have a compaq presario f700. its caps lock n scroll lock keys are functioning but light is not working wht could b the trouble???
most likely the led is blown.
short of stripping down the laptop to replace the leds,,, a pro job,,, just work away without them
Jun 23, 2011 | Compaq Presario 700 470024-192 Notebook
Compact presario f700 laptop will not turn on. It
Was there any power outage in your area and was the laptop plugged in at that time, if so your Motherboard has been fried, your need a new Motherboard.
Jul 19, 2010 | HP Compaq Presario F500 F700 and G6000...
Where does a microphone plug in?
it is usuall at the back of the case next to the speakers. the speakers have a green circle, while the microphone will be purple or pink.
there maybe a port in the front of the case.
Jan 25, 2010 | Compaq Presario 6350US (808736414036) PC...
I have a Compaq Presario F700, how can I activate s-video out?
On most laptops it a simple case of pressing two buttons together, usually th 'FN' or 'Function' Key and 'F5' (press fn first, hold down then press f5) Yours maybe slightly different and use a different F key ie F3.
Nov 22, 2009 | Compaq Computers & Internet
IT CAN BE FIXED.. HANDS ON IS THE BEST WAY . LETS GIVE THIS A SHOT. COMPAQ NOT GOING TO HELP YOU THEY WANT YOU TO BUY ANEW ONE IF IT WORK WHEN IT HAD VISTA , IT WILL WORK NOW, I AM SURE OF THAT. YOU MIGHT HAVE TO HAVE IT COMPLETELY TAKEN APART AND RESET IT , BUT THATS ANOTER STORY , FOR now remove the battery and remove the ram/ memory card, then remove the hard drive , a sigle screw should remove the hardrive memory as well then i want you to hold down the power button for about 3 minutes , then insert harddrive only press power, if you hear a beep good sign if th power button remains after the harddrive is installed, hold power button till computer turns off then install ram memory USE YOUR POWER CORD THREW OUT THIS PROCESS your computer can be fixed i know its easy said then done ITS MINOR but a tech will tell you the total opposite
Jun 02, 2009 | Compaq Presario 700 470024-192 Notebook
Keyboard stuck
Disconnect the power cord and remove the battery. Wait for 30 seconds. Next, put the battery back in the laptop and reconnect the power cord. Turn the laptop on.
Be sure to also run a virus scan\malware check and update all your drivers.
Jun 01, 2009 | HP Compaq Presario 1700, 1700AI, 1700AP,...
Compaq F700 Battery live very less
Its normal, generally it comes with 80-90 min. You can use HP Power management to optimize the use of battery. Making screen less bright will increase the power backup.
Apr 28, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
69 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
