Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My 1tb disk fell from a table and it doesn'st work
My external My Book fell from a table and it didn't want to turn on. I opened it and found out the problem was the connection with the usb/power card. I'm positive the hard drive itself is still fine, but I need a new usb card. Anyone knows where I can find the same exact one they use?
  • 408 Answers
Considering the fact that you can buy them from Western Digital, for an arm and a leg of coarse.  I would say look on ebay for a junk one with a bad hard drive and just swap it.  Other than that you can buy just an empty hard drive enclosure off ebay or newegg pretty cheap...around 20 bucks.  I am taking it your hard drive would probably be a SATA.  But before you buy, make sure the connectors will fit.  it will be long and skinny, which is IDE or short and skinny, SATA.
Posted on Mar 03, 2009
546 will turn on normally(light is blue) but won't display my monitor and usb ports power some items and not others.
You probably dislodged some components in your computer after it fell. Suggest that you open the computer and re-insert the memory modules and other cards inserted in the motherboard. Unplug it first and on a non static surface like a kitchen table.
Mar 22, 2014 | Dell Inspiron 546 MT Desktop Computer
Wd 1600 not working
Western Digital My Book hard drives use USB 3.0 and USB 2.0 speeds to transfer data from the hard drive to the computer and vice versa. When your My Book external hard drive is not performing properly or not turning on, you can troubleshoot the problem before sending the hard drive back to the manufacturer. Correctly powering up and installing the My Book are essential for transferring information and avoiding corruption.
Run your fingers up and down the power cable that connects to the back of the My Book hard drive and the wall outlet in your home. Feel for breaks or tears on the cable and replace the cable if needed. Check the pin on the back of the hard drive where the power cable meets the drive. Make sure the pin is straight and will make contact with the power cable properly. If the pin is bent, send the hard drive to Western Digital for repair. Plug a different device into the power outlet you are using to make sure it works properly. Use a device that you know powers on correctly. b> Slow Transfer Rates b> Open your computer's tower and check over the PCI adapter card that gives you the ability to achieve USB 3.0 speeds. Make sure that the adapter card is installed correctly per your manufacturer's installation manual. If the PCI adapter card is not installed correctly, you will not be able to transfer data in the 3.0 speed. Disconnect any other external hard drives connected to the system. When two hard drives are connected via USB, they share the transfer rate bandwidth and slow your transfer speeds down. Run a Windows Update to change the USB driver on your computer. Click "Start" then "All Programs" and then "Windows Update." Run the update and choose your correct USB 3.0 driver from the list. Click "Install" at the bottom to install the driver. Hope this helps.
Jan 05, 2013 | Western Digital My Book Essential Edition...
Data recovery on blackarmor ws110
http://www.ebay.com.au/itm/120738767650?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
AU $8.40 Buy it Now + postage AU $0.96
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
or you might be able to find one closer for local pick up
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable
yes you would have to remove the hard drive and use a usb sata ide kit
you will have to open up your computer to connect a power lead either sata or molar
http://www.bing.com/images/search?q=SATA+Power+Splitter&qpvt=SATA+Power+Splitter&FORM=IGRE
once connected to another computer to a usb port and power supply you should get a message found new hardware and it should install the drivers
it should show on your computer or you might have to install it manually
click start click on computer to open you should see this drive
if you dont
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver
once you see this drive just click on it to open and copy all or any data you want and save it to another usb drive
hope this helps
or get one of these
http://www.ebay.com.au/itm/NEW-2-5-SATA-USB-2-0-external-HDD-enclosure-case-AU-/221010079433?pt=LH_DefaultDomain_15&hash=item33753a2ec9
NEW!2.5" SATA TO USB 2.0 external HDD enclosure case AU
Sep 26, 2012 | Seagate 1TB BLACKARMOR WS110 -...
I just purchased a Vivicam 25. I installed the CD and then tried to put a few pictures that I took onto my computer, but it is not working. Whenever I try to connect the USB cable to the computer, I get a...
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 28, 2012 | Vivitar ViviCam 25 Digital Camera
My explorist Gc unit...on start up is looking for an active tracking file which is missing. I have a copy on my desktop. How can I get it back into the unit?
You can download the US basemap for the 500 at
http://www.megaupload.com/it/?d=EJTNQH03
Rename it BASEMAP.MGI
Then copy it in the directory "background maps" in the SD card of your 500, by using a SD card reader/writer.
Insert the SD card in your 500 and connect it to your PC; then turn it on;it will turn on regularly, because the basemap in the card will be detected; turn it to USB file transfer mode, and copy the basemap from the SD card to the directory "background maps" of the 500.
If you already have the file ..just rename it like I said ..and copy it ..using the sd card in the reader...Than if it is not functional ..just reset it ..and reload the file the proper way by reloading maps..
Aug 28, 2011 | Magellan eXplorist 500 GPS Receiver
When i restored my mobile settings my memory card locked and didn't open and asking for password i have tried all default passes and none of them worked please help me imei no is 353421045507648
If your photos are stored on the SD card in your cell phone then remove the SD card and put it into an USB memory card reader then connect this USB card reader into the USB port of your compiuter. The computer will see this as an external storage device, then open the photo folder and copy the photos to your computer.
Jul 04, 2011 | Cell Phones
My Seagate portable 320gb external hard drive fell on the floor now my computer and laptop don't see it( won't let me get in to the hard drive) , how do I fix this , Important files on it Help please
Since this external hard drive is USB powered and felt on the floor, you could have a broken USB connector or interface card, both located inside hard disk case, you should contact Seagate technical support or repair service, or if you have electronics skills, you could open and check hardware by yourself.
Feb 18, 2011 | Seagate 320GB Portable External Drive ...
My book essential has worked for several months now til now.... the white light is just blinking and my computer doesntg seem to recognize it anymore what should i do?
From the user manual (click here) on page 4, the slow blinking means that the drive is in standby mode.
The user manual does not explain how to get the drive out of standby mode, but you may want to try the procedure for powering off the drive that is on page 34 that say to press the power button on the back of the unit and wait for the LEDs to turn off.
If the unit does not power-off on its own within a few minutes of pressing the power button, the next thing to do is the following:
Shut down your computer with the drive still connected and powered-up. Once the computer is completely powered-down (no lights on or noise coming from the computer, unplug the power cord of the external USB hard drive and wait a minute. After you've waited a minute with the external USB hard drive unplugged from power, plug the power cord back in to the external USB hard drive Make sure the USB cable from the drive to the computer is properly connected. Power-up your computer using the power button on the computer and let the computer boot as usual. Once the computer has booted, check whether the external USB hard drive is now available.
Happy New Year and Thanks for using FixYa
Dec 31, 2010 | Western Digital My Book Essential 1TB...
Partial format of WD 1TB external hard drive
Look on the Internet for a "file scavenger" program.
Compare it to reconstructing the table-of-contents of a book,
by reading each page & chapter of the last 93% of the book,
and recording what you found & where you found it.
You'll need another 1TB drive, if you find anything to "recover".
Sep 10, 2009 | Western Digital My Book Essential 1TB...
My portable harddrive fell from a low table
i am afraid that the drive has gone, but you could try to fix it using disk manager application.
Nov 17, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
100 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
