Question about Kenmore Elite HE4 Electric Dryer
My Kenmore Elite Smartwash control locked light went on after I finished a load. Now no buttons work. How do I unlock the controls?
  • 1 more comment
  • mann_family Mar 03, 2009
    Thanks to jsrock516, I followed your suggestion and it worked!
  • mwetlaufer Apr 24, 2009
    Mine locked up as well (and of course I threw all my manuals away) Holding the Spin&Drain Button for three 3 seconds worked. Thanks so much!
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Try pressing and holding the Drain/Spin button in for 3 seconds. If that doesn't work, try unplugging the unit for 30 minutes.
  • 5,911 Answers
Just remember, the instructions are printed near the button. This features locks and unlocks the control panel as a designed safety feature to prevent small children from manipulating the controls. In addition, if you get error codes, or the panel starts flashing or freezes up, sometimes these errors can be erroneous. Unplugging the unit for 30 minutes will reset the Central Control Unit (CCU). This is the main "brain" of the washer. Any error code following a computer reset, is usually a genuine problem. If you ever have questions about this washer in the future, please keep me in mind. Congrats on getting it working again!
Posted on Mar 03, 2009
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
How to unlock controled lock
There is a button on the control panel with a marking under it that says "Press and hold for 3 seconds to lock/unlock control". Look for the said button then press and hold it for 3 seconds or until the control lock light turns off. The button is usually the Auto Dry Level button for Kenmore Elite dryers and the Drain/Spin button for Kenmore Elite Washer. Whirlpool Duet Washers and Dryers use the End of Cycle Button to lock and unlock the control.
Sometimes the problem is due to an electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore elite smartwash and the machine says contols locked, is there any way to reset that?
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2010 | Kenmore Elite 45986 Front Load Washer
Control locked. How do you unlock it?
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
Check below link for detailed explanations
http://www.fixya.com/support/r3608801-control_panel_lock
Courtesy JSROCK
Mar 31, 2010 | Kenmore Elite 45986 Front Load Washer
Controls locked light
Courtesy JSROCK
Mar 31, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a kenmore elite smartwash quietpak 9 HE4t. The control locked light is on. I have tried unplugging for an hour and plugging back in, door is unlocked but no buttons work. What can I DO
The following link explains how to correct a Control Lock problem on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
Some front panel features differ between models, but the instructions should be listed on the front panel of the washer, and are located in the operator/owner's manual. If these preliminary measures do not work, you may have a mnore serious problem.
If you have any questions, please let me know. I hope this helps you.
Aug 23, 2009 | Kenmore Elite HE5t Washer
Kenmore Elite Smartwash Quiet 9 I can not locate the manual and my washer says ''control locked'' and I can't do anything. How do I unlock it?
The following link explains how to correct a "Control Lock" problem on a Kenmore Elite:
If this does not correct your problem, you may have a more serious issue. Please post back and let me know. I hope this helps you.
Jul 24, 2009 | Kenmore HE3T Washer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE PROBLEM
Press and hold the control lock button down until the light goes off. This is a child proof feature that may have come on if you leaned against it to long. After lock light goes off you can use the machine.
Jul 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
590 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
