Question about Dishwashers
This dishwasher (MAYTAG DWU6402AAE) is 12 years old, and recently started having a problem with the water. I'm not convinced it's spraying or even rinsing. The soap doesn't drain from the container. Dishes are not getting clean. I'd like to know if there's anything I can do to fix this before I call in a repairman. I'm very handy, and can follow instructions. Thanks. Mike
DWU700BAXSoap dispenser does not open during wash cycle. Kace removed ans cleaned pupp and filter also center nozzle which did have some paper specks but is now clean
Posted on Apr 13, 2009
Having trouble with dishwasher- I feel like dishes are not getting clean- will replacing circuit board on dishwasher help dishing become cleaner?
You may need to clean out the filters that keep food from being pumped up to spray out of the sprayers. This will depend on your make and model as to how to do this. Clogged filters will reduce the amount of water being sprayed. Try opening the door mid cycle to see if there is a vigorous spraying action. If the water being sprayed is underwhelming, it may be clogged filters.
Feb 13, 2013 | Maytag Dishwashers
Dishwasher is leaving a white film on dishes. Tried using less cascade. Washer is about 15 years old. Our water is in the safe zone for hardness, also its well water. Just started this recently.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101 ..
Nov 06, 2010 | Dishwashers
8 year old maytag, clean lime build-up 2 times a year and all the spinning parts look clean and no wear but all of asudden the washer does not clean the dishes very well. Plenty of hot water, soap is...
In you case check the heating element first...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things...
Bought new spray arms online and installed them in minutes...now the thing works like new...
However I have also found that if the heating element goes bad then that also can mess things up bad...
So I would buy new spray arms, and also check out the heating element to make sure it is working...
heatman101
Asker
Sep 23, 2010 | Maytag Dishwashers
Water squirts out but spin bars don't move
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
How to Buy
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jun 18, 2010 | Maytag 24 in. DWD1500A Built-in Dishwasher
Maytag 300 series dishwasher: will not wash
Try pouring water from the front and run the m/c. If Ok ,check. Just 12 litrs enough.
1. water inlet flow.
2. water filter in the machine entry point
Mar 30, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Apr 01, 2009 | Dishwashers
Maytag diswasher won't spray water
water level/float switch is stuck. (dishwasher is getting a indication the unit has enough water in it to operate)...repair/replace float switch, located in front right corner under bottom rack.
clarkco
Feb 28, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Possibly not enough water pressure
It is possible that the valve is not letting enough water through or the spray arms are not distributing it as neccessary for whatever reason it may even be that the motor is weakening with age. If you do the labor yourself it might be worth replacing a part but it is kind of hit miss on what to replace. Appliances average 7-10 years these days. In all honesty if it were my choice to make I'd put the money toward a new dishwasher. Good Luck.
Jan 08, 2009 | Jenn-Air Dishwashers
Maytag dishwasher mdb9600awb - loud pump
This has happened a few times to me as well.(VERY VERY LOUD NOISE AT THE BOTTOM)I have the same model It did stop.I did a little reading and came to the conclusion that it was the built in food disposer chopping blades were chopping up something like a cherry pit or peach pit and once an end of a wooden spoon that dropped down.If you look at your USE and care Guide on page 12 under trouble shooting "Dishwasher seems noisy"..I went through the same thing taking things apart.Its got to be it. Mine is 2 1/2 years as well. Hope this helps. ronkeachie@rogers.com
Sep 24, 2007 | Maytag MDB9600A Jetclean II Built-in...
Leaky float valve
Teresa, the water fill is usually a timed fill and the float assy. is a safety device to cut power to the fill valve in the event the dishwasher keeps filling. ( In most models). Sounds like your initial fill is just above the float lever actuator and dripping. Check the level of the dishwasher to make sure that the water is not higher toward the front. Catriver..post back.
Feb 10, 2007 | Maytag 24 in. DWU7402 Built-in Dishwasher
Dishwashers Logo
198 people viewed this question
Top Dishwashers Experts
Owen Barnes
