Hope someone can help me.Working on a friends thinkpad. First some history
It was working fine. Then it was dropped. They said it worked for a while
then froze and wouldn't reboot.Found out the hard drive crashed. Replaced it
with a 40 gigabyte Toshiba. Loaded Windows Xp and they said it kept freezing
up mostly while booting up. So they gave it to me to work on. I upadated all
drivers and bios. I installed Service pack 2. Here's the problem. When it
first boots up it works great. I started it up and shut it down several
times. But when it is left on for a period of time and then you restart it
it hangs until you lift one side of the laptop and it takes off. Is this a
temperature problem? Or maybe a crack on the board? Thanks
Rating: 0%, 0 votes
disassemble the unit and check for loose/broken connectors or components.
Working when lifting a corner indicates a break or loose connection.
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
problem, it would not start or run reliably at all and simply go
unexpectedly black, especially if moved or the case is flexed. Have a
look at the cabling, especially around the HD since this is where it all
started and remove and reinstall the RAM. Check for a loose or
improperly inserted cable. The restart halt might point to a loose
cable to a device that the OS is polling for and lifting the side
momentarily makes the cable contact. You could try stripping it down to
one RAM stick, the HD, no other cards, drives or network connections and
see if you can narrow the problem to one device. After startup, are
there any devices going missing in Device Manager? Does BIOS setup look
'normal'?
Did the drop visibly damage the case?
Q
Rating: 0%, 0 votes
gets broken when the board expands with the rise of temperature. It
would probably take a microscope and a lot of luck to locate the crack
(assuming there is only one), not to mention being able to repair it.
But you might get lucky ...
John Doue
Post a New problem for IBM for ThinkPad R31 Series Keyboard
Email this problem
Can you Help with these Keyboards and Mice problems?
problem with japanese keyboard
