Question about Alpine CDA-9855 CD Player
Adjusting treble??? how do i adjust my treble sounds ?? there's a certain way to do it but haven't used this cd player in a while so i forgot can someone please help out??
  • panamacity Mar 03, 2009
    ive read the manual and cant find how to adjust treble
    Novelist:
  • 149 Answers
  • Timothy  Lee
    Timothy Lee Mar 03, 2009
    The highs are considered as your trebles
    Press and hold MENU for at least 2 seconds.
    Select the Graphic EQ (User’s EQ) mode by sliding
    your finger on the GlideTouch bar to the left or
    right.
    Press the GlideTouch bar under the Graphic EQ
    (User’s EQ) mode.
    Press BAND to select the band to be adjusted.
    Adjust the level by turning the Rotary encoder.
    Adjustable output level: -6 to + 6 dB
    To adjust another band, repeat steps 3 and 4, then
    adjust all bands.
    When the setting has been completed, press
    FUNC. or the GlideTouch bar to activate the
    preset mode.
    Select any one of the preset numbers (1 through 6)
    by sliding your finger on the GlideTouch bar to
    the left or right. Press and hold the GlideTouch
    bar under the desire preset for at least 2 seconds
    to store the adjusted contents.
    After setting, press and hold MENU for at least 2
    seconds to return to normal mode.
Is the base and treble audio adjustible on this 1996 Sony TV KV- 20S20
Adjusting various sound settings (e.g. bass/treble ... - Sony
docs.esupport.sony.com/imanual/NA/EN/hx850/c_snd_qv.html
You can adjust various sound settings, such as bass, treble, balance, etc. ... [Setting Memory]: Applies custom sound settings to the current input or to common ...
General information on how to adjust the bass and ... - SONY
https://us.en.kb.sony.com/.../general-information-on-how-to-adjust-the-b...
Aug 15, 2015 - Follow this procedure to adjust the bass and treble surround parameters on the A/V ... Adjustable sound field parameters vary by sound field.
Dec 25, 2015 | Sony KV-20S20 20" TV
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
How to set up for bandit 75
What do you by setup for? Are you looking for certain settings to get a certain sound? I'd do a search for the player's name + amp settings. I would try the tone controls first if I was trying to tailor the sound. Try to adjust treble bass, midrange, and try with the volume down and the tone controls all the way up and reduce from there.
Jul 14, 2014 | Peavey Audio Players & Recorders
How come when i push the "A-M" button to use my sound controls all i get is the balance and the fader? no bass and no treble
You can only use bass and treble if your Z-Enhancer is OFF. If it is on excite or bass boost you cannot adjust bass or treble
Oct 14, 2010 | Clarion DXZ665MP CD Player
Does anyone know how to adjust the treble and bass on a JVC KD-G340???
jvc.com, audio car bottom of page click support, model search type in your model number and you will find what you are looking for.
Nov 05, 2009 | JVC KD-G340 Car CD/ MP3 Player
Can not turn the bass and treble up or down on my alpine CDA-9827
ok i cant see your entire question but to adjust bass and treble on an alpine, you see the knob (the one which u use to turn volume up and down), push it in (itll click) then a screen/textt will come up and say bass or an option once it says bass, turn the knob up or down, then press in again and it will say treble or fader or something else, once again, adjust it and keep pressing in the knob until u reach the volume again. does it work? is this what u wanted?
Apr 11, 2009 | Alpine CDA-9827 CD Player
Having Trouble Assessing Bass and Treble Controls
Bass and treble can be adjusted via the sound menu only when the z-enhancer is set to off.
To change them while the Z-enhancer is on (B-Boost, Excite, Impact) choose the enhancer mode, then press the play/ent button. You can then use the up/down arrows to adjust bass and treble to -3 to +3
Feb 18, 2009 | Clarion DXZ375MP CD Player
New car, no manual
There is no straigt forward bass and treble adjustment. You must adjust in either the (x-over) or (users EQ) function. It is a bit tedious but performs the bass and treble adjustments at multiple frequencies.
Aug 24, 2008 | Alpine CDA-9833 CD Player
Troubleshooting on Adjusting Treble/Bass
Look in your owners manual and make sure you are turning the right knobs or pushing the right buttons once you have the adjustment screen for the bass/treble showing. It could be that they use different knobs/buttons than the volume control. If you are using the right controls, then you have a problem that only a shop can fix. You might reset by taking away all the power (acc and bu) for a couple minutes and then reconnect, but if that doesn't help then it time to go to the shop.
Aug 10, 2007 | Alpine CDM-7861 CD Player
Alpine CDA-9855 CD Player Logo
195 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
