Question about Panasonic NN-S532 1200 Watts Microwave Oven
Microwave turns off by itself after being on for 3 seconds
I have a 1200W Panasonic model NNS532WF Microwave, and it turns off by itself after being on for 3 seconds. I would appreciate any help in fixing this problem.
  • pinuss Mar 27, 2009
    I have the same model, and it also turns itself off after 3 seconds,
    how did you manage to fix it?
  • Panasonic Master
  • 9,047 Answers
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt and
http://www.microwavedisplay.com/disassembly.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Mar 06, 2009
We think it is a problem with the door latch cause when this happens with ours, if we open the door and close it again and reset it, it seems to work ok. my son is having the same problem with his. seems to be a common theme here
Posted on Feb 10, 2014
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
Panasonic genius 1200w
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
May 02, 2013 | Panasonic NN-H764 Microwave Oven
Panasonic inverter 900w microwave fault code h97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Sep 14, 2012 | Panasonic Genius Prestige Nnsd997s...
Our Panasonic "the Genius" Model No. NN-S562WF 1200W Microwave has the following problem: We set it for the required minutes, it goes for about 40 seconds then stops - there is no heat happening at all.
hi that is one of 2 possible faults it is either the magnetron or the invertor board (panasonics "great idea" of replacing 3 simple more reliable components (transformer capacitor
Aug 30, 2010 | Panasonic Microwave Ovens
There is a child lock on our Panasonic Inverter 1200w microwave, but don't know how to unlock it. Can you help me?
In my "Panasonic Junior Smart" microwave it's 3 times START to lock and 3 times CANCEL to unlock. Try if that works for your model.
Nov 03, 2009 | Microwave Ovens
Microwave works for 5 seconds
"h98" INTERNAL ICU FAILURE" main control board has failed . will cost 3/4 of the cost of the microwave itself .......... get a new microwave
Jan 22, 2009 | Microwave Ovens
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Jan 04, 2009 | Microwave Ovens
My microwave is a 32ltr 1200w NNT583SF Inverter. it is 4 yrs old. No matter how long i set the timer for it will only work for 23 seconds, then it just switches off??
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 05, 2008 | Panasonic Microwave Ovens
Microwave works, new noise
It could be a bad magnetron, or it may be mild arcing due to food particles or grease on or behind the waveguide cover.
No microwave should ever be left unattended while running.
Jun 24, 2008 | Microwave Ovens
Panasonic NN-S532 1200 Watts Microwave Oven Logo
2,079 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
