Question about SkyScan 86742 Digital Atomic Wall Clock
Outdoor transmitting 3M PRECISION Clock Includes Calender,Alarm And Indoor & Outdoor Temperature The outside temperature is not transmitting back to the clock
  • 5,568 Answers
These devices have a limited range, normally 20-30' (~6-9m) and that range is influenced by the material that separates them. Any metal structures in their path can shorten the useful range. Also, I think all of these transmit only a second or two every few minutes to conserve battery power.
Posted on Mar 08, 2009
How to set up taylor `model 1731
  • Indoor (32°-122°F/0°-50°C) and outdoor (-4°-140°F/-20°-60°C) temperatures. Lower outdoor temperatures achievable with lithium batteries; Indoor and outdoor humidity. Includes temperature and humidity trend indicators; Daily min/max recall for temperature and humidity. Features a calendar and clock with alarm; The wireless remote sensor transmits up to 200 ft. The base station and wireless remote require 2 AAA batteries each, not include. If you want essay related topic you can go for custom essay writing service will get better result.
New Generation Custom Essay Writing Service with Intelligence EssayCaptains
Feb 06, 2017 | Taylor Health & Beauty
Just put new batteries in both units but can't get the oudoor temp to show - what have ee done wrong?
Replacement has to be done in a certain order.
  • Remove all batteries
  • Install batteries in outdoor unit. Allow time for unit to initialize and begin transmitting temp.
  • Install batteries in indoor unit. You should see outdoor temperature displayed.
You may find that the outdoor temperature is not transmitted in very cold weather. Right now it is below freezing and my indoor unit is showing - - for outdoor temperature.
Dec 13, 2016 | Measuring Tools & Sensors
WEATHER STATION AC100MB stops transmitting outdoor temp
I have experienced the same with numerous different, "quote un quote" atomic clocks! Please don't forget that this sender unit, that goes outside, generates a RF Singal to be received by the clock inside. This unit transmits a signal 433 MHz signal approximately every. 3 minutes, and after so many years the sender unit's RF section(electronics) just goes out or no longer function properly or not at all! The transmitter/sender for this model number, according to "3M" is obsolete and can no longer be furnished, DRATTS !!!!!
Mar 20, 2012 | 3M Measuring Tools & Sensors
I have a TX6470 and cannot receive the outside temp on the inside unit
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. If there are reset buttons, also try them.
Oct 16, 2010 | Timex TX6490 Wireless Thermometer with...
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
Outdoor temperature doesn't transmit below about 32 degrees.
I have one of these, and below freezing, the sensor is frozen.
Apr 18, 2009 | SkyScan 86742 Digital Atomic Wall Clock
3m precision clock lost instructions
HOLD SET BUTTON UNTIL ITEM YOU WANT TO CHANGE FLASHES. USE + AND - BUTTONS TO CHANGE ITEM . PUSH SET TILL IT RUNS ON.
Oct 25, 2008 | SkyScan 86742 Digital Atomic Wall Clock
OUTDOOR TEMPERATURE
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
SkyScan 86742 Digital Atomic Wall Clock Logo
365 people viewed this question
Top SkyScan Home Experts
nejones57
nejones57
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a SkyScan Home Expert? Answer questions, earn points and help others
