Question about Dell TrueMobile 2300 Wireless Broadband Router (TM23001)
No this did not solve my problem. i am looking
No this did not solve my problem. i am looking for how to access network settings for wireless connection (true mobile 2300 router).
  • ear_ot Mar 09, 2009
    Could not find a WEP code on back of router.
  • pbeck May 11, 2010
    I'm sorry,
    What was suggested that didn't work?
    Are you looking for the default password for your router, or did you changes it and have forgotten it?
    President:
  • 2,049 Answers
"Network settings" is a very broad term. I have to assume you don't have a manual to refer to to find the setting you need to change. Use this link to see the entire user's guide...
http://support.dell.com/support/edocs/network/p57205/en/index.htm
Posted on Aug 05, 2009
How to secure my home network wifi how to put a password?! it appears that it's Unlocked..
Wireless network passwording is done at the router, in the wireless setup area. Log into your router using the admin userid and password. Go to wireless settings and there you will see the option to set a password for the wireless network. One you set the password and save it, all devices that connect to your network wirelessly will need to be reconnected to the network, using the password you selected to gain access to the network.
Sep 17, 2016 | SENAO High Power 200mW USB WiFi 802.11bg...
Slow connection low signal
If a wireless network has low signal strength, the transfer of information across the network could be slow or you might not be able to access certain parts of the network. Here are solutions to some common problems with low wireless signal strength: Your computer is too far from the wireless router or access point. Move your computer closer to the router or access point. If your computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer. If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than the built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna. The wireless router or access point is turned off or isn't working properly. There are two things to try: o Make sure the router or access point is turned on and that the wireless signal light is illuminated. o Reset the router or access point by turning it off, waiting at least 10 seconds, and then turning it back on. If you don't own the access point or don't manage the network, contact the network administrator. There is interference from other devices. If you have 802.11b or 802.11g network hardware, it uses the 2.4 gigahertz (GHz) frequency. Other devices that use this frequency include microwave ovens and cordless phones. If you have 802.11a network hardware, it uses the 5 GHz frequency. Some cordless phones also use this frequency. These devices can cause interference between your computer and the network. There are two things you can try in this situation: o If any devices like these are near your computer, turn them off temporarily or move them farther away. o Change the router or access point settings to use a different wireless channel, or set the channel to be selected automatically if it's set to a fixed channel number. Sometimes one wireless channel is clearer than others. In the United States and Canada, you can use channels 1, 6, and 11. Check the information that came with your access point or router for instructions about setting the wireless signal channel. The network you're looking for is set to not broadcast its network name (SSID). Wireless routers and access points can be set up so that they don't broadcast the network name. In this case, you can't detect that the network is in range (in order to connect to it) unless you've previously connected to the network or you manually connect to the network using the service set identifier (SSID). To connect to a network that's not broadcasting, follow these steps: 1. Open Connect to a Network by clicking the network icon ( or ) in the notification area. 2. Click Unnamed Network, and then type the network information. The network will be added to your list of networks and will be available to connect to in the future when your computer is in range of the network.
Dec 27, 2012 | Computers & Internet
I forgot my password
Which password you are looking for?
If you are looking for wireless network password then you will need to access the router setup page and check the wireless settings.
IF you are looking for password to access router settings then default password of Linksys router is admin.
To check the wireless network password see How to find wireless network key WEP WPA
Jan 08, 2012 | Linksys Wireless-G Broadband Router
Trying to connect DSI to internet
These instructions come from http://www.nintendo.com/consumer/systems/dsi/en_na/usb/index.jsp and should be able to help you solve your problem. Good luck!
  1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
  2. Scroll over to the third page, and select "Internet."
  3. Now choose "Connection Settings."
  4. Click on "None" for "Connection 1."
      connection_1.png (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  5. Click on "Search for an Access Point."
  6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds. Look for your wireless network. (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  7. What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi. Click the image below that matches the lock icon you see on the screen of your Nintendo DSi.
May 07, 2011 | Nintendo DSi White Console
I am having a Compaq nx6325 and recently inside my office we had setup a wireless access point. When I try to view the list of available wireless networks (after enabling the wireless system on my...
Could you connect to the network when hard wired? If not then check the D-link and make sure the LAN set up is correct. If you could then you know the problem is with the wifi only.
When to look under Device Manager does it show that the wireless adapter is working?
Do you see any other networks available? If so you have a mismatch between your router set up and your computer network settings.
Go to NETWORK CONNECTIONS, Right Click on Wireless connections, PROPERTIES. Look to see if Microsoft Client, File and Printer Sharing, and Internet Protocol (TCP/IP 4) is checked. Then click on TCP/IP , PROPERTIES and look at the settings. The GATEWAY must be the same IP as your D-Link, The default IP for the router is 192.168.0.50. If it was set up with a different IP address make sure the wifi gateway is that same address.
If you put in a "KEY" when setting up the wireless router, WEP or WAP make sure you use same when trying to get on the network. You won't get that far if you're not seeing the network on list at all.
Try setting the machine in the same room with the D-Link. Will it detect the network now? If so consider interference with the signal ie metal in the wall such as a furnace.
These are the most common reasons for problems so try these first.
Feb 18, 2011 | Compaq Computers & Internet
Where do I look on my "main" computer (hard wired
Hi dkusner,
Welcome to Fixya. If you need your Wep/Wpa Key (Passphrase) we can access the Wireless Settings Page of the router to obtain the information needed.
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key (Wep/Wpa Key) or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Don't forget to say thanks. Thanks for using Fixya
Feb 10, 2011 | NetGear WGR614 Wireless Router
Wireless Internet connectivity not working.
Does it recognize your wireless network?
I your wireless switched on on the laptop, most laptop have a separate small switch to swicth on/off the wireless option, indicated by a small antenna with some waves.
Does it recognise any wireless network at all?
Try connect to a hotspot or unsecured network to see if that works. Double check all settings for your own network in your router and your laptop. 1 typo in a security password can be enough to be unable to connect.
Aug 08, 2008 | IBM ThinkPad R52 Notebook
I have a laptop run Vesta trying to set wireless connection to HP Potosmart C4385 print using ad hoc network setup. When selecting Ad Hoc connection in the printer setup it saids it can not find it or...
For this specific issue about installing the printer to a wireless connection. You need to install the software first as a usb connection. After the successful installation of the usb connection then you can add a device and it should work.
Step one: Gather the necessary hardware and information Follow the procedure below before obtaining your wireless network:
  1. Obtain your network SSID and WEP. To simplify this process, press the Wireless button on the all-in-one, and select Restore Network Defaults . This turns wireless off and sets the all-in-one's SSID to hpsetup .
  2. Press the Wireless button to turn wireless back on. Look for hpsetup when you select your network.
  3. Make sure that wireless is enabled on the all-in-one.
  4. Make sure that the computer that will be using the all-in-one has access to the router/access point.
You will need the following to set up the product on a wireless network:
  • A wireless 802.11 network that includes a wireless access point.
  • A desktop computer or laptop with wireless networking support or a network interface card (NIC).
  • Broadband Internet access is required for some features of the HP software to function. Cable Internet or DSL are examples of Broadband Internet access. NOTE: If you connect the unit on a wireless network that has Internet access, HP recommends that you use a wireless router (access point or base station) that uses Dynamic Host Configuration Protocol (DHCP).
  • The network name, or Service Set Identifier (SSID). NOTE: The SSID is obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.
  • The Wired Equivalent Privacy (WEP) key or Wi-Fi Protected Access (WPA) passphrase, if needed. CAUTION: To prevent other users from accessing your wireless network, HP strongly recommends using a password or passphrase and a unique SSID to your access point. Your access point might have been shipped with a default SSID, which can be accessed by other users using the same default SSID. For more information on how to change the SSID, see the documentation that came with your access point. NOTE: The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.Some access points provide more than one WEP key. Use the first WEP key (index 1) when setting up the wireless network.
  • If the network is set up with an Apple AirPort base station and you are using a password instead of WEP HEX or WEP ASCII to access this network, you need to get the equivalent WEP key. See the documentation that came with the Apple AirPort base station for more information.
  • If IP address filtering is set up, verify that the unit address is listed.
  • If MAC address filtering is set up, verify that the unit address is listed. NOTE: HP cannot set up or change the SSID, WEP key or WPA passphrase. This information is required before connecting the HP All-in-One to the wireless network.
Step two: Connect to an integrated wireless WLAN 802.11 network Follow the procedure to connect the unit to the wireless infrastructure network:
  1. Insert the software CD.
  2. Click Install .
  3. Click Next on the Please Allow All HP Install Wizard Processes screen.
  4. Select Easy Install on the Choose Easy Install or Advanced Install screen.
  5. Select Through the Network on the Connection Type screen. Figure 2: Connection Type screen c01160788.jpg
  6. When it doesn’t find your device, click Next . Figure 3: Using Network Setup c01164746.jpg
  7. Plug in your device via USB (it will tell you when to disconnect later). Figure 4: Making a connection to your all-in-one c01160790.jpg
  8. Select your network from the list, and click Next . Figure 5: Wireless Network Setup c01160791.jpg
  9. Enter your WEP key (if applicable). Figure 6: Specifying your network security settings c01160792.jpg
  10. Once it has completed connecting to the network, click Next . Figure 7: Network connecting completed c01160793.jpg
  11. Disconnect the USB cable from the computer and the All-in-One . Figure 8: Disconnecting the USB cable c01160794.jpg
  12. Click Finish to complete the software installation process. Figure 9: Software installation complete c01160795.jpg
Aug 04, 2008 | HP Office Equipment & Supplies
4350 Small Network Access Point's web-based configuration tool
If it is trying to connect to the internet when trying to get to the tool, you have to get a direct link to the tool. You might find this on a forum somewhere. It might also help to update your firmware, this may solve your problem immediately. The only problem with routers is that they are built to connect to the internet.If you don't have the internet it is a tedious job to get access to your access points settings. Just get the link to the page and you should be able to change your settings then.
Feb 22, 2007 | Dell Wireless 4350 802.11g/b Wireless...
Unable to access the network
There are two things you can try, one is renaming the SSID in the Wireless settings from the default (WLAN) to another name then release and re-new the IP addresses. If that does not appear to work try uninstalling the Wireless USB network adapter(s), reboot and reinstall and that should solve the problem.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Dell TrueMobile 2300 Wireless Broadband Router (TM23001) Logo
138 people viewed this question
Alun Cox
