Averatec laptop 2300 will start and run the boot screen and then it shutsdown like in the sleper mode i do not have any software for the computer
Acer Travelmate 230 laptop starts up shows the Acer screen then gets to the windows loading screen after that the screen goes black and does nothing else. what can i do?
What operating system do you have?
What happened prior to the issue? Did you do an update/ installed a new software in your computer?
Try to boot to safemode:
1. Turn your computer on and tap on F8 before the splash screen appears. 2. You will get a black screen that says Advanced Boot Options. Choose Safe Mode with Networking. 3. If the issue does not reoccur there, the problem might be related to the video card driver. Uninstall the video card driver:
a. Click start, right click on My Computer. Choose properties b. Go to Advanced tab and click on device manager. c. click on the plus sign beside display adapter. d. right click on the video card driver found there and uninstall. It will prompt you is you are sure you want to delete it. Click yes. e. Then restart your computer. Boot to normal mode (just let it boot and do not press anything as you boot the computer)
The issue should not be present in Normal Mode but your screen resolution will be very different (bigger). Download the correct driver for your computer from the links posted below:
video driver 1 or video driver 2
Jul 05, 2011 | Acer TravelMate 2300 Notebook
Avweratec 2300 will not turn on
have you tried running it in safe mode? if it starts up then go to your start menu>all programs>accessories>system tools>system restore. go to a date before hand were it did work and your computer will restore itself.
Sep 10, 2009 | Averatec 3200 Notebook
Averitech 2300 laptop won't boot up...
It seem that it's an hardware issue . You can contact local hardware vendor and may be some part need to be replace
Sep 05, 2009 | Averatec 2260-EY1 Notebook
Averatec won't boot
Hellor
To catch the fleeting screen hit the Pause/Break Button it will stop the scrolling. By keeping your finger close to the key you can Press Pause, Read a few lines, then Pause, a few more till you read the whole message.
You can reinstall an old version of the OS, or even insatll Linux (it is free), but I will not guarantee that your special program will run. But if you install Wine on you Linux you can run Windows programs in virtual mode. Warning if your special program is on the hard drive you will erase it when you install Linux.
Hote it helps.
Sep 04, 2009 | Averatec 3200 Notebook
Averatec 3225hs windows xp won't boot up
Hi there.
Turn on the computer and press the [F8] key during the POST procedure. this will take you to a sub menu where you can choose to boot into safe mode.
If you need any more assistance please post back.
Good luck and thanks for using Fixya!!!
Feb 19, 2009 | Averatec 3225HS (DH3225HS) PC Notebook
Averatec laptop won't turn on normally
is the clicking sound coming from the cd rom or hard drive
if either of this are bad , it will do all that
Jan 02, 2009 | Averatec 3200 Notebook
Averatec 6100 series closes all programs before i can open them
Try tapping either F5 or F8 (can never remember which) as soon as anything shows on the screen on boot. One of these will bring up a short menu with your available choices for boot.
Nov 02, 2008 | Averatec 6100 Notebook
Averatec 2300 laptop will not power on.
The problem is that the computer does not get enough power when you turn it on and that's why it doesn't boot.
Try to put a random CD in it and leave it there for an hour maybe two. By spinning the CD, more volts get through the mainboard. Then shut it down by pressing the power button and then press it again and see the results. If this wouldn't work the first time, try it again.
May 13, 2008 | Averatec 3200 Notebook
We need to determine if the problem is your graphics chip or if the laptop really isn't booting. Do you get any kind of hard-drive activity light when you boot it up?
Slow to freeze
There is some virus in PROCESS.But try this solution:
Restart pc and logon with safe mode ( F8i think ) then log on as user u use pc normally!Then go start -run-then type msconfig -enter.Go to startup and desable all programs(DON'T DESABLE ANTIVIRUS)
Let me know if u got help!
Mar 11, 2008 | Averatec 6200 Notebook
Computers & Internet Logo
David Payne
David Payne
