Question about Honeywell Programmable Thermostat Heater
The heater runs and doesn't want to shut itsself off
We tried to replace the thermostat.  Now the heater wants to run continuously.  It is a new Honeywell thermostat model RTH230B
    Problem Solver:
  • 23 Answers
Check the wire to the thermometor then if the wire is ok replace the thermostat
Posted on Mar 03, 2009
Why does furnace fan run continuously?
No on the thermosat go and check fan is not on the summer switch setting , if the fan is running it could be the AFC automatic fan control not shutting the fan off
Dec 29, 2012 | Honeywell Heating & Cooling
The thermostat works fine for heat, but as soon as I switch it to cool, the air conditioning will kick is but the inside thermostat will not change, causing the air conditioner to run continuously
If the temperature doesn't drop when the air conditioning is running for some time (two hours), the air conditioner is not working. The problem is not in the thermostat.
Gary
Jun 14, 2011 | Honeywell CT500 Digital Heat / Cool Manual...
Had a problem with the thermostat connected to GW-50-4 Wall furnace. One fan is not working at all, the other fan runs continuously even when the furnace isn't running. Is there a control swith or...
Jake, it sounds like the motor coil wiring on the blower that doesn't work may be damaged or has been disconnected.
Regarding the one that is still running. The automatic fan control is located on the bottom of the blower assembly. The fan control is a nonadjustable, automatic type. The fan control will require between 3 and 7 minutes of main burner operation before the fan control "closes" and activates the blower. The blower will continue to run between 3 and 7 minutes after the main burner shuts off, before the fan control "opens" and deactivates the blower. In which case, if it continues to run and run and run, the fan control switch (part # R-2503) may have failed and will need to be replaced. You can order the part from Empire Comfort Systems Tech Service 800-851-3153. Have the Model Number, Serial Number of the heater handy, as well a the Part Number. when you call.
To help you further, I have included a link to the Owner's Manual for that model wall heater. You can download and print it for future reference.
http://www.empirezoneheat.com/assets//EHS/manuals/GWT-%2825,35%29_Manual.pdf
I hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Empire GWT-50 Wall Mounted Panel Heater
Dryer runs for about 10 minutes than shuts off. And it doesn't seem to be generating heat. Problem?
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermostat. When the thermostat goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, if thermostat reads continuity then please get back to me if you have any other questions.
Kevin
May 14, 2011 | Frigidaire Affinity AEQ6000WH Dryer
Hi, I have a Dayton 3ug73 heater. The heater will not shut down after the initial heat requirement is met. I have the thermostat set on low but it continues to heat. I shut the power off to it to keep...
It sounds to me like your thermostat may be bad. I would check power incoming to t-stat then turn temp. setting up and down to see if it is switching on and off. If not then replace. If it does then I would check all wiring to gas valve and if power is shutting off to valve but burner continues then replace gas valve. Thank you.
Mar 07, 2011 | Dayton (3UG73) Electric Utility Heater
The heat never cuts off. already changed the battery but it just keeps running. do i need a new thermostat?
Try disconnecting the W wire and see if the heat continues to run. If your unit has electric heaters, and the heat continues with the W or W2 wire disconnected from the stat, it may very likely be stuck heating relay/sequencer.
If the heat does shut off after disconnecting this wire, then the problem has something to do with the thermostat. Replacing the battery was a smart. You can also check to see if your thermostat has a reset button or a fuse.
Mar 22, 2010 | Honeywell Electronic Programmable...
I have a Rheem Heat Pump and a White-Rogers Thermostat. Right now my heater will heat the room to the exact temperature I have it set to, but it never shuts off. It does not continue heating, so I can only...
Try checking the switch, you may need to have it replaced. Your heating system is still okey, but the
fan continues running even when switched off, Is this
what you mean? Then, have your switch checked, especially the electrical line going to the fan.
Jan 04, 2010 | Honeywell Programmable Thermostat Heater
The radiator fan of the car will not turn off when I shut the car stays on
It's an electric fan and this is not uncommon for any vehicle. Have your coolant lines pressure tested and flushed you may need a new thermostat. The fan runs on a temperature switch and this may also be a cheaper repair to make first..the fan runs because it is told she's all hot n' stuff...it's a good thing until you make specific repair....I'm assuming it's your thermostat.
Aug 29, 2009 | Volkswagen Golf Cars & Trucks
Gas heater shuts off & won't come back on
sounds like the thermostat replaceing it should help you could try cleaning the old one they can get dust it them
Feb 25, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
203 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
