Question about GE Spacemaker JVM1640SJ Microwave Oven
Bulb replacement One bulb was already gone, tried to replace the other bulb (forgot to unplug the microwave). There was a flash and the bulb broke off. Does this mean I can't replace the bulb anymore? Anything I should watch out for? thanks.
  • GE Master
  • 9,098 Answers
Yes, do be sure to unplug the oven first when removing or installiing bulbs.
This is pretty common and can be a pain. It's tacked in place with contact cement or hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Once you get the new bulbs in, if they still don;t come on or they won;t go off, then your control circuit board will need to be repaired.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Mar 06, 2009
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Was removing a burned out bulb in my LG LMVM1935SB LG Microwave cooktop/oven. The bulb broke, and we had to finish getting the bulb out of the receptacle. The other light worked, but now apparently is...
When removing a bad bulb ALWAYS unplug the unit. If there is power going to the bulb and when you try to take the bad bulb out and the glass seperates from the bottom base the leads will short out and you will blow your main curcuit board. Then the entire board must be replaced. It will blow out a component on the board or blow a trace off of the back of the board. either way either baord repair or replacement will be needed. ALWAYS UNPLUG THE UNIT WHEN REPLACING A BULB!!!!
Sep 18, 2017 | LG LMVM2075 Microwave Oven
How do i change the light bulb? Panasonic model NN-T945SF
Do you mean you want to replace light bulb for your microwave? If yes follow the instructions below;
  1. PLEASE UNPLUG YOUR MICROWAVE!
  2. Picture of your microwave with a phone or camera so that you don't forget how to assemble it back.
  3. Remove the two screws that holds grill. They are located at the edge of the unit. Once the screws are out, rotate the grill forward from the top. It will pop right out.
  4. Once the screws are out, rotate the grill forward from the top. The grill should pop right out.
  5. Locate a small access cavity on the left.
  6. Remove the screw that is located near the front of the microwave door.
  7. Lift up the sheet metal floor to access the bulb. The bulb is located under the sheet metal "floor" on the left.
  8. Place a flash light on the microwave floor and shine the light in the light area. This will help you see better when you replace your bulb.
  9. Look for a small shiny reflector that hides the bulb. Use your two fingers to squeeze it a bit. Making sure not to bend it.
  10. The bulb connection should come right out.
  11. After you replaced the bulb, re secure the reflector and the sheet metal floor with the single screw. Test the bulb by plugging in your microwave.
  12. Once you see that the bulb works. Unplug your microwave again and re attach the front grill. You are now done.
I hope this helps to solve your problem.
Good luck.
Apr 09, 2011 | Panasonic NN-S541 Microwave Oven
How do I replace light bulb
Good luck.
Apr 08, 2011 | Daewoo Microwave Ovens
How to change microwave bulb
Hope this help in solving the problem, take care.....
Sep 16, 2010 | Microwave Ovens
My light in the microwave has gone out. Is there
Bulb replacement was designed into the appliance, meaning that; Yes, you can replace it and it's rather simple.
First, UNPLUG the appliance! You're working with the door open, so the bulb socket is hot (charged) even though the bulb is dead.
For the overhead light, the bulb is located behind a plastic splatter-shield that clips in place...Press the clips in to remove the shield, and un-screw the bulb (lefty-loosey).
For a sidewall bulb, there are the same clips holding it in place, but they are recessed and you may need a butterknife or to pop them out: UNPLUGGED, RIGHT?
What matters most are 2 specific shopping details; Wattage and base size (width)...The first detail is stamped/printed on the original bulb, and base width (not diameter) is easy to determine by laying the old bulb on a ruler.
Overall bulb size doesn't vary much, and is easy to match at the supplier.
Which was the other part of your question: Where to buy.
Most Walmarts carry a small selection of appliance2_bing.gif bulbs, and your local Lowes or HomeDepot have a few more to choose from...You will need those 2 shopping details to zero-in on the replacement, then verify that the overall size of the glass is the same or smaller.
(A bit smaller is OK, provided the wattage and base-size are the same...but too wide or too tall, and you can't get the cover back on.)
Best Buy can order the bulbs for you if their service dept doesn't have it in stock, and Sears offers the same service.
When all else fails; Hit the Yellowpages under "appliance parts" for a local parts shop...The bulbs are for the most part fairly generic, and any decent parts shop will have a few in stock.
Mar 28, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
Ge profile spacemaker XL 1800 undercabnet microwave
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Sep 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Flash and Bang on Closing Door
Since you know that the bulb is blown that needs replaced. I would go ahead and replace the bulb and see if it works. I doubt that it will. If not unplug the unit and remove the exterior case. Locate the secondary fuse and replace it with the same size and rating. Plug in and try but be prepared as it may do the same thing again. I am not sure what you mean by 'lay up' your unit. If it was not running (heating) it should not be the magnatron. Sounds like the bulb blew taking out the fuse which would cause the other problems you described following the flash. Good luck.
Jun 12, 2007 | Kenmore 63672 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
75 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
