Question about Acer Aspire 5050 Notebook
Acer apire screen wont come on
I have 2 acer 5050 laptops i just replaced the dc jack on both now the screen will not come on any ideas yes there pluged in
  • dnny_dg Mar 05, 2009
    all conections are good had them checked
  • 46 Answers
Did you reconnect the display panel connector correctly? Remove the keyboard again to make sure.
Posted on Mar 04, 2009
How to replace the DC Power jack of my acer aspire 7735Z
Replacing a DC Power jack in any computer is no easy task. However, it can be done by any novice. First, get on ebay and see what jack you need. Search for you jack by entering Acer Aspire 7735z jack. Most of the new ones have the cable attached to the jack instead of the old fashion solder.
Next, Google this question and check out the YouTube videos regarding Acer DC Jack replacement. It will give you an idea as to what you need to do. You may want to take a video camera and record what steps you take when you take it apart so you can review how to put it back together. Also, get a sewing box or something so you can put the screws in a separate container for the order you removed them; ie: bottom screws; hard drive screws, DVD mount screw... etc..
You always have to start with the bottom and work your way to the top. You will have to remove the palm rest, keyboard, heat shields and any other piece of hardware to get to it.
YouTube is your friend...
Aug 12, 2014 | Acer Laptop DC Power Jack for Acer...
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
My acer aspire 3680 could not power on by bat and adaptor
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 08, 2010 | Acer Aspire 3680 Laptop
I have an Acer Aspire 7736z which wont charge. Ive already found that the battery connector/battery pin/battery port whichever youd like to call it has snapped off. Any information on how to fix it? where...
DC Jack diagnosis:
Sep 28, 2010 | Acer Computers & Internet
Acer 5570z will not boot up or turn on
It could be one of the following:
1. Bad/damaged power jack.
2. Bad motherboard.
DC Jack diagnosis:
Sep 26, 2010 | Acer Aspire 5570-2067 Notebook
Acer travelmate 5520 will not switch on when powered by battery or ac
Sep 22, 2010 | Acer TravelMate 5520 Notebook
I try start up my apire 6920g but it light up shortly every time i touch the button, but nothing happens except the quick flash...i guess its something with the power??
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Sep 17, 2010 | Acer Computers & Internet
Screen wont come on
what did you try already?
Mar 03, 2009 | Acer Aspire 5050 Notebook
ACER apire 5050 screen keeps going blank/freezing
Hold down the "Fn" Key and press the "F4" Key, wait a min, press the Enter key on the keyboard... Do this when it happens, the problem is the ribbon cable in the laptop that goes to the screen is loose, If you want to fix permanently, send in for repair to Acer if under warranty.
Dec 17, 2008 | Acer Aspire 5050-3242 Notebook
Acer apire 3000 dull screen
select primary display from the disply setings and select externel disply as primary
Dec 02, 2007 | Acer Aspire 3000 Notebook
Open Questions:
See all Acer Aspire 5050 Notebook Questions
Acer Aspire 5050 Notebook Logo
82 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
