Question about Kingston 1GB PC2700 DDR DIMM Memory
PC RAM What do they mean when they specify RAM like this: 512MB 64*8/32*8/32*16
    Scholar:
  • 150 Answers
Looks like that could mean different combinations of RAM sticks that add up to the total amount. Such as 16 sticks of 32 to get 512 MB ram. You shouldn't need to worry about this, as most RAM sticks these days are at least 256. So if you need 512 Mb of Ram all you need are two 256 Sticks.
Please Rate, Thanks!
Posted on Mar 09, 2009
    Problem Solver:
  • 13 Answers
This refers to the data width and chip configuration. 64*8 is an 8 chip 512MB module. (8 components @ 64MB each) 32*8 is an 8-chip 256MB module. (8 components @ 32MB each), etc.
Posted on Mar 05, 2009
Hangs splash screen
hanging on splash could mean failure in the ram, video card or CPU cache. Try new ram. Good luck.
Aug 04, 2014 | WYSE Winterm V90LE Thin Client - Thin...
Motherboard is giving 3 beeps.
Hi' please specify *********** board for confirmation , but i can give you a sort of trial , Try to put or insert again the 512mb ram and if it works good again so your 2gb ram may not be compatible as there are classification of ram DDR1,DDR2,DDR3,depending of what mother board you are using,IT maybe the right RAM you replace but when you inserted it it might be a little loosen,Please don't hesitate to contact me anytime ,thanks
Apr 29, 2012 | Asrock P4VM890 Motherboard
I have 2 pcs of RAM, 512MB and 1GB. then my pc has 4 slot. Can I install both 1GB and 512MB?
yes you can install it but issue is that . Is your computer supports the both bus peed first check the bus speed for checking bus speed you can see a steker on ram on that print will start form like
512. 400. its it speed is 512mb and buss speed is 400
if your 1gb ram is also 400 bus speed its mean it will run your computer smoothly.
if buss speed is change so you will face trouble. so please confirm the bus speed first thanks
Jul 16, 2011 | Computers & Internet
Hi everyone! I was just wondering if it's possible to have a 512MB RAM and a 1GB RAM in my laptop (Acer Aspire 3634WLMi) at the same time or if you have to have two of the same... Thanks for your help! :-)
The laptop support 2GB of ram. There are 2 banks for ram each supporting 1GB each.
Of course if you want to install 512MB in there you can although having matched memory is always a good thing. For example 2 sticks running at 400MHz (PC3200).
Regards.
Jul 01, 2010 | Acer Aspire 3634WLMi Notebook
Hello, I have a Satellite A15 @129 w/756 MB RAM. I'd like to upgrade but don't know the maximum RAM stick each slot will take and don't remember if there are 2 slots or 4. Thanks, RD
The maximum RAM for this laptop can up to 1 GB DDR1 266MHz RAM and 2 memory slot available, so since u have already 756 MB RAM in your laptop, that mean 1 of your RAM stick is 512MB and another 1 is 256MB, so if u need to upgrade, u have to replace the 256MB with 512MB to make it 1GB maximum.
YBC (/\)
Oct 07, 2009 | Toshiba Satellite A15-S129 Notebook
Is MSI 865PE Neo2-V motherboard support graphic work?
Most of the applications that you have specified above use high amount of the memory. If you are using vista this makes it even worse. Get another 512MB RAM and install it in the next DIMM slot and it will be alright. 512MB Ram should cost you around 500-700Rs.
Nov 13, 2008 | MSI 865PE Neo2-V Motherboard
My G4 466 graphite won't see my low density 512mb sdram stick!
As long as the 512MB RAM chip is running at 133Mhz it should work, it may have compatibility issues with the other RAM in the unit. Try removing the other RAM first if it does not work after that you probably have a faulty piece of memory.
Oct 16, 2008 | Apple Computers & Internet
My computer is to slow
you did not specify what is the speed of your processor, and the memory of your ram. anyway if you computer has a ram memory of 512mb you need to install an additional ram and try to maximize. if the maximum ram memory is 2gigabytes do this to improve the performance of your pc
Jul 30, 2008 | Compaq Computers & Internet
Can you expand the memory on a Systemax Intel SIS651 System
Your motherboard is actually a Foxconn 651M03.
According to your system you have :
512MB DDR333 PC2700 Non-ECC Memory (512MB x 1)
(One stick of 512MB)
The motherboard manual says this:
System Memory
Two 184-pin DDR DIMM slots
Supports PC1600/PC2100/PC2700 memory
Supports 64Mb/128Mb/256Mb/512Mb technology up to 2GB
(This means you can have a total of up to 2 Gigabytes of RAM)
If you upgrade your RAM, you will need to make sure that you get the correct type.
If you want to keep the RAM you have, you will only be able to have 1.5 GB of RAM because you only have two slots to work with. If you want to upgrade to the full 2 GB, you will need to buy 2, 1 GB sticks.
Jul 17, 2008 | Computers & Internet
Kingston 1GB PC2700 DDR DIMM Memory Logo
85 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
