Wont charge...sometimes wont turn on....very fickle as to when it wants to work and when it wont...if I repeatedly plug it in and out of my computer I then may be able to get it to turn on but it is rare I can get it to keep a charge.
    Sergeant:
  • 239 Answers
Did you try plugging it in to a different usb port?
if so it sounds like your mp3 players hardware has an issue. you might want to take it in to exchange it, if it is still under warranty. if not you might want to buy a new one. as they don't really sell replacement parts for them.
hope this helped.
please rate well
Posted on Mar 03, 2009
  • 523 Answers
Its not charging well, this means the charger is not giving the dc capcity that it needs.try another charger and let me know what happen? if you did this means the internal battery is becoming weak.
Best regards
  • 13,433 Answers
Hey, hows warranty?
The battery is most likely almost dead, and there may be a connection problem on the usb plug, can you try another cable and see if it improves.
Also whats the brand and model of your device?
  • 19,396 Answers
Check the charger connector.
  • Ginko
    Ginko Mar 03, 2009
    Check the USb connector , there may be a broken contact in there, also the internal battery may be faulty, how old is the player, and what model?
Will not charge
Kodak camera wont charge? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 1, 2011 - My Kodak EasyShare M580 digital camera wont charge. I have the USB charger, but when I plug everything in, the charging light wont light up, ... Kodak Easyshare camera will not charge?
Mar 27, 2014
My kodak easyshare m580 WILL NOT charge?
Mar 14, 2012
Kodak Easyshare M580 Not Responding To Charger?
Dec 7, 2011
My kodak easyshare m580 will not charge?
Apr 16, 2011
More results from answers.yahoo.com
Nov 29, 2015 | Kodak Easyshare M580 Digital Camera
Ipod wont work
If it is under warranty still retrieve the serial number from the back of the iPod and call Apple to setup an appointment at your nearest Apple store to save you time. They only take appointments now that I know of.
If by resetting you mean by:
Holding down menu & play/pause?
If that doesn't work plug it into the computer, make sure you have iTunes installed and then try restoring it. And if THAT doesn't work, make sure you have the lastest iTunes, and firmware. Sometimes computers are a little iffy, if the connection noise is present and disconnected it could be the USB port. Sometimes on my phone/mp3 players it'll do that and they only liked to be plugged back into the same original port the USB driver was installed on. So if you plugged it through the front when it was working try that.
Jun 08, 2010 | Apple Audio Players & Recorders
Wont charge
1.) Was the computer turned on and booted up?
*The USB ports provide no power under most computers when they are not on.
2.) Does the iPod work when plugged to the cable?
*If so then you more than likely have a faulty battery or port that is not allowing charging.
May 07, 2010 | Apple iPod nano
My Ipod touch wont Charge
keep it connected and see what happens
Mar 21, 2010 | Apple iPod touch
3rd generation wont turn on
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Hope this helps :)
Apr 25, 2009 | Apple iPod nano 3rd Generation
Zune won't turn on or charge
probly a lemon battery. Get ms to replace it.
Jan 07, 2009 | Microsoft Zune JS8-00001 Digital Media...
My ipod nano 4th generation won't turn on and it is charged. sometimes the screen freezes.
push the hold button on the top to the right then to the left then hold both the center button and the menu button till you see the apple logo it should work fine after than
Oct 05, 2008 | Audio Players & Recorders
My ipod nano wont do anything
Try this
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
if noting helps, see the bottom of the page for service information.
May 06, 2008 | Apple iPod nano
Camera Wont turn on and blue light flashes
The possible answer is that batteries are past thier best now and even a 'full' charge is not delivering enough power. treat your self to new batteries.
Aug 13, 2007 | HP Photosmart M425 Digital Camera
Wont stay on
I suggest removing the battery when plugging it to the wall outlet or are you trying to charge it? I think the one that is spinning is the hard drive reseat it then lets see what happens try to purchase a new hard drive if problem persists. please indicate also the status of the lights on your laptop ill reply with more steps when you've indicated everything
Mar 22, 2007 | Dell Inspiron 1100 Notebook
 Grubhead
Grubhead
