Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
I have installed a Honeywell CT8775C, when I put it on the heat the A/C goes on!! I have checked my wiring and everything looks right? what should I do to correct it.
    Novelist:
  • 189 Answers
You should have a minimum of four thermostet wires. The red wire goes on the R terminal. White wire on the W terminal. Green wire on the G terminal. Place the yellow wire on the Y terminal. In most cases NO other terminals are used...... IF YOU DO NOT HAVE A YELLOW WIRE...... place the blue wire on the Y terminal. This should hopefully fix it. IF NOT....See if the thermostat has a RH and a RC terminal. If so I'll bet that you put the red wire on RC ternimal. this is for airconditioning ONLY. The RH terminal is for heating ONLY. Put a small jumper wire that will connect RH & RC. Then this should solve your problem.
Posted on Mar 08, 2009
I have everything hooked up rth9580 Honeywell thermostat and still no power. What else to do ?
IF this is for a heating air conditioning system, there is a transformer on a box near the inside unit, it is protected with a fuse and should have a switch on it, check those.
Apr 08, 2017 | Honeywell Heating & Cooling
5 ton goodman package unit not coming on
If you look on the install manual. It says it will work for a heat pump without backup heat. No heat strips.........If you do not have strips the guide says as follows
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
Mar 25, 2014 | Goodman Heating & Cooling
Just installed Honeywell RTD7500d thermostat to replace Batstat239 (which seemed to have faulty temperature gauge - it would keep pumping both hot and cold past the set point indefinitely). I followed the...
Wiring seems right, but it needs to be wired like the original tstat. Meaning if W was connected to w1 on the old, that's were it goes on the new. If it was on aux heat then your wiring seems correct. If its operating the aux heat "on its own", then that's were your issue is at.(?) Also, there is a configuration menu in the new tstat. It needs to be set up for your system, heat pump, 1 cool, aux heat or 2 heat 1 cool, O should engage the reversing valve(RV=O). If you didn't write down or pic what you started with, it will be tough for you, and us, to wire your unit correctly. And there is no factory installed fuse on the outdoor. The indoor will(should) have a 3 or 5amp "blade" fuse, (car fuse but not the new smaller style, the 80's to 90's style). Its on the indoor circuit board. Hope this helps!
Feb 28, 2017 | Heating & Cooling
I have a T6060B honeywell thermostat that is not working. When I looked in it, the earth and live wires are on the same connector. Is this right? I am hoping to replace it with my Dad's old one, that seems...
Honestly, you term for "earth" wire stumps me. So I asked Mr. Google and searched by image T6060B Honeywell, and seen different wiring on different t-stats. I've never had the chance to install what you have, but if you're changing it with Dad's old 1, and they are identical, wire it the same way if it was working/had been working properly for some time.
Aug 20, 2017 | Honeywell Heating & Cooling
Where does the W2 wire go?
w2 wire is second stage heat does your furnace have two stages.look at gas valve it would have 2 valves/ sol w2 will go to w2 on stat. if a single stage furnace w2 is not used
Jan 25, 2010 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Improper Termperature Readings during AC run
personally i'd just replace the thermostat, but try pulling the front panel off and look on the circuit board and see if there is a jumper for F/C or any other settings. you may try changing its position. you can also remove the batteries for 15 minutes and see if it resets itself. the only other thing it could be is a wiring issue.
May 29, 2009 | Heating & Cooling
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Installing thermastat
any wire can go to any terminal. unfortunately you now have to hand trace each onre to the device it powers and hook it up accordingly. a daunting task even for a pro. having said that the installer could have used the normal colrs for the usual wiring if you were real lucky. as a general rule the red goes to the r terminal. the yellow goes to the y terminal. the white on a heat pump usually goes to w2. the green powers the fan and goes to g. usually the changeover valve is powered by the o terminal and that is usually wired with an orange wire. that only leaves two more wires. one is the auxilliary or emergency heat terminal and any color wire can be used for that. it will go back to the airhandler and tie on to the w terminal along with the white wire from the stat on most units. or they may have jumped the w and emergency terminal together and hooked the white wire to both. it will work either way. that only leaves one wire and that is the common wire to the stat taht allows it to light up and think and have power. . most stats need the red and a common to work. you may have bought a stat that works off battery power only but since you are blowing fuses it seems you have a common pulled on one wire that you have hooked up wrong and it is creating a dead short , aka a blown fuse. if you go to airhandler and finf low voltage terminal board look for terminal labeled comm . observe what color wire is connected to it and if that is the wire that goes off to the stat. if it is hooked to common and goes with the others to the stat then thats your common and should be hooked to your stat common terminal as outlined in your install sheet. you can keep replacing those fuses till you get it right or take a chance and use an amp probe and a jumper wire . only run an instant and if amps are 4, 5, 6, amps at trans your wrong. only test an instant or you will ruin transformer.probably best if you get a box of fuses.label stuff make notes and good luck. i have gotten in the habit of using a sharpie pen to make copius notes right on the service panel for me and the next guy.
Oct 30, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
304 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
