Question about Motorola Mobility RAZR V3
Phone frozen on main screen
The phone turns on, rings, and the alarm works but when you push any button it will not dial out, you cannot answer or turn off alarm. It is frozen on the main screen.
  • Anonymous Mar 05, 2009
    mine did the same thing today. Have taken the battery out and also cleaned the terminals but still doesn't work.
  • 653 Answers
Tyr turning off the power and then starting back up after a few minutes. If that doesn't work, try taking out the battery, leaving it out for a few minutes and then starting it back up. If that doesn't work, call customer service.
Posted on Mar 05, 2009
  • Fahr Quad Mar 07, 2009
    Did that work???
Toshiba dkt 2010-sd voice mail doesn't answer
To help you I would need to know what type of Toshiba main cabinet you have. If you have a CTX or CIX it may be that your system call forward is turned off. If you dial #620 at the extension in trouble it will turn the system call forward on. #621 turns it off. The proper sequence for "No Answer Call Forward" is Press ext. button + #6031 (tone) + dial main ext for voice mail + timer (08~60)
(tone) . #6051 removes this type of forwarding.
Mar 12, 2014 | Toshiba Strata DKT-2010-SD Digital Display...
I can not answer the phone if an unknown person rings
If you have tried a power cycle, and this does not help, you may have only one option left than to do a master reset.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your Motorola DEFY is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and hold the Power button until the device turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Downfor NO
Feb 28, 2011 | Motorola Mobility Defy Cell Phone
I push the feature button it turns red as soon as i enter the phone number the light goes out press feature and does not program
Why are you pressing the feature button?
Press feature then answer. You envoked ringing line pick up.
Press feature then speed dial button, dial a number like your dialing out, then feature again. You've just set a speed dial button.
Press feature, then 3 and you've changed your ringtone on a series i phone.
Mar 16, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Push numbers whilst talking on phone
1. FYI, when your call is dailed through successfully - please pay attention as there are two instructions on the screen. It tells you to press which button for dailing and which to press to unlock the screen.
2. To answer your question: On the left hand side of the phone, there are 3 buttons. Press the button at the bottom below the volume up & down buttons. The dailing screen should come up.
This button is also used as a shortcut for changing profiles quickly in the main screen.
Jan 22, 2010 | LG Prada KE850 Cellular Phone
O dial tone and screen just flashes off. fully charged.
just tried neighbours phone in and that worked so when we put our phone back in it worked again.
Aug 23, 2009 | Philips Lands Phones
Samsung prostar 816 plus system ringing problem
sounds like your having a couple of problems at the same time. the lines only ringing at station 1 is the default setting of the system my guess is that the time and date are also way off if thats the case.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
next, the problem with the cordless not working has to do with the port programming, in default it assigns all ports as multiline sets.
To assign a SLT(single line telephone) port to the system while still in program mode dial #38 the screen should say slt dial type and then 16 0's.
0 = keyset 1=slt set
enter in all 16 digits followed by the # i.e.if your cordless is on port 7 it would look like 0000001000000000 #
lastly the phone that can no lnger recieve calls sounds like the do not disturb or DND has been pressed to stop the alarm from ringing. press the mute/dnd button (light should be off). to cancel an alarm press the ALM/SD button twice and then the hold button.
hope that helps out.
Mar 05, 2009 | Samsung Prostar 816 Phone
Vintage phones cannot dial out
Any standard phone should work, even phones made in 1800's should still work on a standard phone line.
I'm not sure what phone you have. The one listed in the question "M7310" is a business system phone and will ONLY work on the Nortel business phone system.
If you have standard home phones, my only suggestion (using the information supplied) is to check if the Tone/Pulse switch is set to tone... even though both should work.
Do you have phone service through a cable line?
May 28, 2008 | NorStar M7310 Phone
How do I turn off Alarm only
On the left hand side of the phone (on the side) there are up and down buttons. Push the button up and it will change the ringer status
Feb 07, 2008 | Samsung SCH-u540 Cellular Phone
Motorola Mobility RAZR V3 Logo
119 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
