Question about E-Machines eMachines Desktop PC
Have a emachine desktop T3508 and I need a manual. And nothing happens with you apply power.
    Scholar:
  • 73 Answers
Try here.
http://www.emachines.com/support/options.html
The site does not support downloading of their manuals. I tried to find other information or manuals but cannot reach other sites on www.emachines.com at this time, I think they might be having site issues. I will keep looking and keep you posted. http://www.emachines.com/support/product_support.html not loading at this time from my location.
Posted on Mar 03, 2009
The battery is fully charged, and the ac adapter is plugged into the laptop, when i push the on button the laptop will not start
Remove the battery and power source. Remove the RAM and hdd. Power up with the power supply and it should do something. If it does, replace the RAM and hdd it should now restart. If nothing, check the GPU.
Jan 10, 2017 | Computers & Internet
Are 2002 Aztec computers compatible
I am assuming you are discussing the 2002 Pontiac Aztec, the early crossover with the rather distinctive look. I would assume that since they were made by the same manufacturer and they used the same parts that their computers should be compatible. I can't say so for certain as you haven't provided much information, but, unless one of the Aztec owner swapped out the original computer and replaced it with an updated device, the computers should be compatible.
If you are thinking of trying to swap computer chips, I would advise you to wait and let a professional do it at an independent shop. The reason I suggest this is simple, unless you know how to access the computer chip correctly, you risk accidentally ruining it. If you handle the replacement chip incorrectly it is entirely possible that for a stray static charge to ruin the chip by blowing out a trace. Also, if you damaged the socket from which the original chip was removed then it is possible that you will not be able to reinsert the new device without bending any leads on the bottom. If the leads are damaged, then the new computer won't work.
Even if the new computer chip and the original chip were already installed in installable cases (the way most desktop computer chips are installed), it is possible that when you removed the computer, you might have damaged the receiving socket which means that when you go to insert the new computer carrier it won't work correctly because a few or many of the pins on the bottom of the board won't sit correctly.
Jan 03, 2015 | Computers & Internet
How do i turn off the HDD
What happens when entering the sleep mode is the drives will be turned off and the present state will be kept in memory until awakened. While the system is active the power scheme will prevent the drives from idling down after so many minutes with the never turn off setting applied.
With the turn off drives after the default 20minutes of inactivity that doesn't mean all drives turn off at the exact same time. I've never come across any reference for changing the power plan option for individual drives. But I can point you at the guide for the power plan settings with one instruction on drive settings to apply prior to entering the sleep mode.
hope that helps if not let someone here know.
Oct 03, 2014 | Computers & Internet
Ibm thinkpad 2374 manuals
Does it actually have a wireless network adapter? Check the network adapter settings. Does it show both LAN and wireless? If it does you may need to use one of the Function keys to launch the interface to turn on the wireless.
Aug 19, 2014 | Computers & Internet
I need an operating instruction manual for a panasonic workstation js790ws
I only could find the 795. The other links goto fake sites, that promise manuals, but try to install something on the commuter.
Perhaps this can help:
http://panasonic.net/pss/pos/pdf/925ws_manual_us.pdf
Jul 22, 2014 | Computers & Internet
How to convert desktop hard drive to external hard drive?
See this... http://voices.yahoo.com/converting-old-computer-hard-drive-into-external-1481521.html
Jul 13, 2014 | Computers & Internet
I do not have a printer to download anything,
samsung chromebook manual here
http://static.highspeedbackbone.net/pdf/Chrome%20OS%20User%20Guide.pdf
or hp chromebook here
http://www.shopping.hp.com/shopping/pdf/f2j07aa.pdf
Jun 03, 2014 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
Toshiba Satellite A665 S6067 laptop wont recognize my SeaGate FreeAgent Go 500 Gb. device
I had a similar problem and I had to "Delete Volume" when in DIsk Management. I then had a choice to "Create Simple Volume" which I did, and then a wizard created the correct partitions and assigned a drive letter to my external drive. Everything was them OK.
Mar 21, 2014 | Computers & Internet
E-Machines eMachines Desktop PC Logo
264 people viewed this question
Top E-Machines Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
