Question about Estro Barista Athena
Estro da5p error message "Out of Order 2"
We have a Estro da5p that we got from someone a while back, however it doesn't work!! We keep getting an error message that says "Out of Order 2." Any ideas as to what the matter is?
I got a used machine that had been sittign for years. On the first several tries to power up, I got that error message a short while after powring it up. My water jug is installed externally for easy access, and I could see the water wasnt getting up the hose all the way to the machine. So I elevated the water jug by placing it on top, then the water fed and the message didn't appear. This may not have much to do with your situation, but maybe it will help. (Maybe error 2 relates to water shortage) You could remove the back panel and see if water is filling the tubes. (Caution with hot wires)
If you don't have manuals, I saw them here.
http://www.partsguru.com/VendingmodelDA5P.html
Good Luck
Posted on Jun 09, 2009
Ge pss26sgpass keep in defrost error code bc ?????
That is actually a "tc" error code.
This error means that the display board isn\'t communication correctly with the temperature control sensors which is why it\'s giving the error. It may stop cooling so you need to keep an eye out. Either way, try to unplug the unit for 5 minutes (don\'t plug it in early it\'s hard on the compressor). Plug it back in and see if the error goes away. If it doesn\'t, you need to order and replace your display control board because it\'s just not working correctly unfortunately.Here is the board to order.
Dec 01, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
I keep getting an error saying my printhead is missing on my lexmark printer
Try to clean the contacts of the printhead and the printer. If it doesn't work, unplug the power of the printer for about 30 seconds and plug it back in.
Sep 17, 2012 | Lexmark Prospect Pro205 Wireless...
I'm tyring to print this morning and message comes up need to order supplies, then I look what I need and change it but this message error keeps coming up 50.2 fuser error before and after I change the...
When a 50.x fuser appear its because the fuser its worn, its probably overheating. I can suggest to take it out (in the back you will see 2 blue locks) for about half hour (turn the unit off before you are doing that) and put it back in. If the error persist you need a new fuser. Good luck
Aug 23, 2010 | HP LaserJet 2840 All-In-One Printer
I keep getting error message 2908, can you help????
I haven't even gotten this program installed yet due to the above error message. I am NOT going to pay someone to help me install this program, instead I will send it back to the manufactureres.
May 22, 2008 | ValuSoft Print Workshop 2003 for PC
My Dell printer doesn,t copy or scan it gives me error 2200
- Turn off the printer first
- Remove the power supply and pressed the power button for 15 seconds
- Clear info out of the printer
- then plug the power back in and press the power button.
Oct 24, 2007 | Dell 962 Photo All-In-One InkJet Printer
Perpetual windows protection error loop!
use a win ME startup floppy disc. get to DOS and run scandisc.exe on c drive. if still no progress afterward, then repeat but this time, load cd driver and then re-install windows.
Oct 20, 2007 | Computers & Internet
ERROR MESSAGE
please check and clean the unit where ink cartridges are located
Sep 21, 2007 | HP 920 Plain Paper Fax
?Scanner failure? error message
Usually this type of error message pops up when the scanner lamp isn?t warming up properly. This is what you should do: 1. Check if the lamp is on. 2. Unplug the scanner?s power supply and plug it back in. Try connecting it diretly to the wall. 3. If that doesn?t work: a. Unplug the unit?s power supply. b. Press ?cancel? and left arrow while reconnecting the unit. c. Release the buttons when the printer starts up. 4. Try scanning again. 5. If it doesn?t work, have it serviced.
Feb 22, 2006 | HP PSC 750 All-In-One InkJet Printer
Estro Barista Athena Logo
209 people viewed this question
Top Estro Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Estro Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
