Question about HP Compaq Presario Media Center SR1750NX (EL445AA) PC Desktop
HD521-2W error The computer will not boot to desktop.It just keeps going to the bootup selection screen then regardless of what you select.it starts booting all over again.I googled this error and found out the hard drive is either weak or has already failed.Any Help with this?
  • kenny_boy37 Mar 05, 2009
    I reformatted the computer and I guess I had an issue with the boot registry.The Computer is back up and running great now
You could have defaulted the boot menu and signed in just fine.it may have been comprimised.hide your keyboard.
Posted on May 07, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
What you have found out is right. Also an issue of your RAM. you can check both of them
Posted on Mar 03, 2009
I have a Asus G73JH Windows 7 64 bit operating system. Frequently it crashes into the blue screen of death and subsequently when i try to restart it. I get the select proper boot option error. Upon fu
press F8 on bootup and select SAFE MODE. try to login and do normal things. if this works then this is probably just a driver or application issue. if SAFE MODE doesn't work, this is probably a hardware issue.
Start your computer in safe mode Microsoft Windows Help
Mar 27, 2014 | ASUS Computers & Internet
How do I get my Vostro 1000 to bootup
Try going into safe mode. Press F8 when you start the computer and then select "Safe Mode with networking" you should then be able to run a couple of diagnostic programs or a virus checker. You can even do a system restore from there.
Apr 20, 2013 | Dell Vostro 1000 Laptop
I have a desktop 1200 .. the browser has been hajacked.. how do I start the computer in safe or restore mode
As the computer boots up, press F8 and run in safe mode when the screen pops up. I recommend more over using a command line scanner to identify and kill the hijacker (suggest DR WEB CURE IT)
free and effective
Jan 22, 2011 | Gateway Computers & Internet
Screen black with error message of bad resolution
follow theses instructions to resolve your problem :
- Restart your machine
- Press F8 rigght before Windows bootup
- In the menu select "VGA mode".
- Once your system boots, click with mouse right button on the desktop.
- Select Screen Resolution/Properties.
- Navigate over the windows, until you found the resolution categorie.
- Change your resolution to 1280 x 1024 or lowest one, 1280 x 1024 is Max.
- Press OK, and then confirme your choice.
- Enjoy.
Dec 26, 2010 | Samsung SyncMaster 912N 19" Flat Panel LCD...
I installed 'speed up your PC' by Uniblue and now my windows XP PC continually reboots to the advanced menu page where you have the option of a safe start, revert to previous settings and normal start. ...
Yes, you can use a Bart PE Boot CD. I've used it several times to do many repairs , even blue screens and fatal errors . Follow the steps exactly as I'm going to list them for you . (Before starting this, make sure the BART disk is already in the computer CD Drive. Don't worry if it spins up...It will load when you complete the following steps.) Also, be sure you are not connected to the Internet and if you have a wireless connection , disable it as you do not want to access the Internet while doing the repairs to your computer's XP system files .
1. from computer startup, press F1 or whatever keys to press to access your BIOS / CMOS utility screens to select "Boot Sequence" to change your boot device options to first boot device is CD ROM. Sometimes it will be the F12 key at startup to change "Boot Order"
Regardless the procedure you'll use , the the end result is that the CD Boots FIRST. Save changes and exit, usually by missing F10 if in BIOS. Regardless, we want the computer to boot the CD Drive from power ON.
2. Once the computer reboots from the CD ROM , be patient and don't press any keys while BART loads its files and applications .It will display several screens while loading up . The last task screen it will display should be the network support attempt to connect screen . After the program realizes there is no Internet network connection , it will display its inability to connect . Then the computer screen should look similar to the default XP desktop display.
3.left click your mouse on start (lower left of the screen ) . Several applications and tools will appear on the list . Scroll up to disk tools and select it or highlight it until the disk tools options appear . Select check disk . You'll notice two or three check disk options . Select the one that just says check disk. Left click on it to start the application . If you have selected the right one it will display a menu of options beginning with which drive you want a check and you will manually enter your C drive as per the exaple it shows. Then, it will prompt you for two specific details you will have to decide on. I don't remember the exact wording, however, I can tell you what you want to select . Select the " /r " (repair) option for sure. Also, select the thorough check option that "takes longer" to complete but recovers lost data and repairs clusters and sectors . Be sure to take your time and confirm your selections as required before the check disk application starts .
4. Once it starts to run , don't touch the computer . It may take awhile to complete the task . I've seen it take as long as 60 minutes to complete . Regardless , once it is finished it will display the details of what it found wrong and what it repaired If there were any problems or system errors on the hard drive . If it displays that it found errors and corrected them , close the application , THEN REMOVE THE CD , and finally, use the the standard shutdown procedures you normally use and select Restart.
5. Dont worry about the boot sequence , as it will default to your C: drive (hard drive) after it fails to boot from the CD ROM .
6. Hopefully, your computer will start and run normally .
7. If it doesn't , repeat the Bart CD loading procedure and try some of the other options available , such as the registry checker , etc. however , be very careful how you use the Bart disk tools as some of them are complicated to use and can cause irreversible hard drive failure if not properly run . Be careful . The check disk option has worked for me 80% of the time without having to do anything else . Good luck
Sep 05, 2010 | Microsoft Windows XP Home Edition
My computer keeps going back to the screen asking
Reboot the computer, on start up, press Alt +F10 and set your computer back to a earlier date or do complete restore, hope this helps!
Mar 19, 2010 | Sony VAIO VGN-FS742/W Notebook
My computer monitor was disabled so now it is black is there any way to reset it or enable the monitor?
Alyssa,
Two ways:
1. Power On the computer and get into the BIOS settings screen. The monitor will turn ON and allow you to view the menus. Select the integrated peripherals menu and set the "use internal vga" ON.
2. If your computer has a add-on video card, unplug the monitor cable from the internal monitor interface and connect it to the add-on video interface.
Nov 07, 2009 | Insignia D400a PC Desktop
Acer laptop bootup problems
Please try and bootup your computer in safe mode by pressing the F8 Button just before windows starts to load. a menu appears and you just need to select the safe mode option and see how it goes from there.
Let me know if this helps.
Oct 27, 2008 | Acer Ferrari 4000 Notebook
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
Jun 05, 2007 | Acer Aspire 3610 Notebook
HP Compaq Presario Media Center SR1750NX (EL445AA) PC Desktop Logo
261 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
