Question about Palm Tungsten T5 Handheld
Palm t5 will not shut off, it will only display palm logo screen. How do you flash the rom on the t5
  • mdr022473 Mar 03, 2009
    After soft and hard reset, touchscreen will only display Palm logo and will not shut off. How do you flash the rom
  • Palm Master
  • 19,396 Answers
  • Palm Master
  • 1,800 Answers
Its not an esay task but u can try the update utility that cames with it cd if u dont have it u can download it from mean support and dwonload section.
aslo if is not working use our repair directort and locate nearest reapiar shop to u and tell them about flashig my phone.
Posted on Mar 03, 2009
    Master:
  • 404 Answers
There is a small hole in the back, you need a needle or a very small wire to push that button down and hold for few seconds. then it will reset (you lose data and everything)
  • Palm Master
  • 13,433 Answers
Perform a reset, a hard reset and also let the battery run out.
I'll look into the firmware.
White Palm Centro freezes randomly. Doesn't respond to input
http://forums.palm.com/t5/Support-Downloads/Palm-Centro-ROM-Update-for-Freezing-Issue/td-p/165101
Mar 28, 2010 | AT&T Palm Centro Cell Phone - White
Palm tungsten t5 won't boot past the Palm Powered
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your T5, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm Tungsten T5 Handheld
How do you flash the rom on tungsten t5
Sir now you have to upgrade the software of your phone
Jun 01, 2009 | Palm Tungsten T5 Handheld
T5 is frozen on the "Palm Powered" screen
Remove the battery and let the palm sit for a day, reconnect the battery and do a hard reset. To remove the battery, you need a Torx T5 screwdriver. Carefully remove the cover making a note of the location of all the buttons in the case. The battery is connected by a mini 2 pin connector, just disconnect the battery by gently wiggling the connector and pulling.
Mar 06, 2009 | Palm Tungsten T5 - Multilingual Handheld
pls try these steps first
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1156,E=0000000000310371479,K=2039,Sxi=10,case=obj(33016)
otherwise update rom from here
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(15356)
pls rate me fixya if i have fixed ur problem
Mar 03, 2009 | Palm Tungsten T5 Handheld
Dead Palm
Need to change the battery.
Jun 01, 2007 | Palm Tungsten T5 - Multilingual Handheld
Interrupted update - jammed
An interrupted update will corrupt your ROM. I sincerely hope you'll get a better 2nd opinion, and from your post it seems like if theres a solution out there then you're not likely to miss it ;] Good luck, and let us know if you worked it out
Apr 17, 2006 | Palm Tungsten T5 Handheld
Switch from outlook to palm desktop
Remember to change (HotSync, Custom) settings before you perform your sync or else you will get duplicate records as I did. Good luck. Support Knowledge Library Click here to go back Click here to print Solution ID: 25263 Switching between Outlook and Palm Desktop synchronization Depending on your device, you might be synchronizing with Outlook using the Palm™ Outlook Conduits, or PocketMirror conduits from Chapura (find out which). Both of these types of conduits are installed and activated when you run the CD-ROM that came with your device. What do you want to learn about? * Switching synchronization: Palm Outlook Conduits * Switching synchronization: PocketMirror Conduits * Synchronizing partially with Palm Desktop, partially with Outlook * Note about data transfer * Macintosh information * Multiple users on the same desktop computer Switching synchronization: Palm Outlook Conduits These instructions apply to the Palm Outlook Conduits that are included with handhelds released after late 2003. The Palm Desktop installer determines which conduits are activated during the installation process. If you want to switch synchronization from Palm Desktop to Outlook, or vice versa, you'll need the original CD-ROM that came with your handheld. 1. Insert the CD-ROM into your computer. A window should open, containing the contents of the CD-ROM. 2. From the Discover Your Handheld screen, select "Install Microsoft Outlook Conduits" or "Change synchronization method" (depending on which device you have) 3. Follow the instructions for switching synchroniztion from or to Palm Desktop or Outlook. 4. See our note about data transfer Remember: Some applications will continue to synchronize with Palm Desktop. Use Palm Desktop to manage applications such as Photos and VoiceMemo
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Open Questions:
Palm Tungsten T5 Handheld Logo
23 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
