Question about York Yankees Bedding MLB Comforter
My york propane furnace will not lite, ignitor glows but will not lite. checked the gas have a full tank
  • 2,840 Answers
Hi sounds like the presure switch jump it out and see if it fires up
Posted on Jan 22, 2010
  • 70 Answers
Gas valve is bad
Posted on Oct 05, 2009
Laars pilot not glowing
remove wires to ignitor see if voltage to them if so bad ignitor if no voltage check safety circuit
Jun 05, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
York furnace won't ignite
Is the igniter receiving 120 volts after the pressure switch closes? If not, either the board is bad or the pressure switch is open
Nov 27, 2012 | Heating & Cooling
Kenmore propane dryer 70 series does not lite
Assuming the gas is on. The most likely problem is a bad ignitor. Remove the bottom front panel(pop 2 clips at the top of lower panel with a flat screwdriver) and turn the dryer on Look for the ignitor to glow. If the ignitor does not glow test leads to ignitor for power if you have power replace it. If the ignitor glows then you are not getting gas check to make sure the gas supply is on.
I hope this helps if you need further assistance please let me know.
Apr 14, 2010 | Kenmore Dryers
Ignitor glows but no heat and we know the gas is on. It would light a day ago but would not stay on. Now it will not even come on but the ignitor glows. The AC works. We wonder if it is the circuit board ,...
Make sure the gas valve switch is turned on, if you
have another gas source other than natural gas make
sure your tank is full and turned on.
If you are mechanically inclined, you could try to
take the cap loose on the drip leg of the gas pipe and make sure you have gas to the furnace.
If the igniter glows but shuts off, usually mean there
is a problem with gas valve or vent system
Jan 09, 2010 | Goodman GMS90703BXA Heater
York Diamond 80 furnace (propane conversion), about 1998 model. Solid Ignitor comes on, but no flame. Main fan works for about 90 seconds then cuts off. Fan only switch on thermostat does the same, fan...
Check for 24 volts across the two terminals on the gas valve when the ignitor glows. If yes, bad gas valve or blockage in the gas train. If no, bad ignitor or circuit board. Even if the ignitor glows, it still may be bad and not sending the proper signal to the board. If you jump the R and G terminals on the circuit board, does the fan still only run for 90 seconds? If so I would say replace the board.
Dec 28, 2009 | Heating & Cooling
York furnace model p2mpd12h06401f flashes 4 times for trouble code does'nt have code list inductor motor comes on but ignitor does'nt come on
Check pressure switch for inducer motor. If switch closes, check for crack in ignitor. If gas valve opens and you can hear/smell gas, the ignitor is bad probably. If pressure switch isn't closed you need to check for blocked vent/chimney/heatexchangers.
Dec 18, 2009 | York Furnace Draft Inducer Blower Fasco #...
90 + gas furnace. inducer full of water
need help with gas furnace put in new presure switch and it worked for a while now i have to blow into it to get it to turn on ignitor .
Dec 05, 2009 | York Furnace Draft Inducer Blower Fasco #...
HSI ignitor is glowing red but furnace isn't lighting every time
most likely the gas vavle only buy honeywell valve the rest are junk
Jan 08, 2009 | Jenn-Air JED8230 Electric Cooktop
York Yankees Bedding MLB Comforter Logo
443 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
Shehu Pro
Shehu Pro
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
