Question about PPI PCX-280 Car Audio Amplifier
RODEK AMP PROTECTION
As soon as i turn the radio up it goes into protection dont know why i even tried it on different setups
  • 77 Answers
Have you checked your speaker connections and any other connection for shorts or multiple ground loops. cause that will definately cause the protection mode.
Posted on Mar 04, 2009
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Kicks the overload protection breaker very often
known issue with these you need to order a motor upgrade kit, let me know if you need me to order you one?
Jun 06, 2010 | Polaris Ranger RZR Ride on Toy
Amp goes green at first then protection.
check the impedance load or try a different ground. when you hook your ground up always make sure you sand the metal down before you connect to ensure a good and clean connection.as for the impedance, make sure your subs are wired to the right ohms. for example, if your subs are wired to 2 ohms or even 1ohm, and your amp is only 4 ohms, then it will do exactly what your saying it does.
Sep 19, 2009 | Car Audio & Video
Kicker amp goes into protection mode as soon as i turn it on
Have you tried powering on without speakers connected? Have you tried powering on with no input? If either senerio causes the amp to NOT go into protection mode, then there is most likely a short in wiring. Use a multi meter to isolate.
Jun 11, 2009 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
My blaupunkt gta 460 goes into protection
Check the speakers wires for a wrong connection,check the speakers maybe they are not support the power of the amplifier,good luck
Jun 05, 2009 | Blaupunkt GTA 460 4 Channel Amplifier 800...
Rockfordfosgate P6002 amp protect light goes on
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
Mar 17, 2009 | Rockford Fosgate p-450.4 Car Audio...
My car amp wont come out of protection mode.
hey i had this happen to me, pull the deck out and move the rca cables to a different channel and see if that does not fix it. i blew out my sub pre out channel in my deck and had to use the rear pre outs. try this and let me know what you come up with. good luck
Mar 07, 2009 | American Pro Car Audio & Video
Radio shuts off at volume of 16 or more
Maybe a protection component cutting in.
If you have speakers that are too powerful for the radio it may shut down to protect the amplifier from overdriving the speakers. That produces too much heat in the amp chips/transistors and they either have a overload cut out protection circuit or they burn out.
Even if the speakers are the stock fitted ones the wattage could be bigger than the amp in the radio can handle.
There's probably no way of knowing how powerful the speakers in the truck are but you could try the radio with another set.
Max 50 Watts for that radio. If you don't have the manual for it, it's available here:
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Mar 07, 2008 | Kenwood KDC-319 CD Player
DAB2204
try turning down the volume level on the power amp.
And see if that works.
Dec 27, 2007 | Digital Audio 840 WATTS 2, CHANNEL HIGH...
Amp protection
Hi, Off hand, I believe there is nothing wrong with the setup, maybe just not 100% compatible. It's just that the Sony Amp's protection is doing its job (just too good) and the stock radio is likewise doing it's job (but not too good). Just maybe, at poweron, the stock radio sends out a small burst output (maybe capacitor discharge) that we normally hear as a slight thump in the speakers which was when no Sony amp, ok. However, when you have added the amp, you also amplified the thump, which unfortunately the Sony protection reacts to. You can off course let it be since you have figured out a way to make it work or you can try and install a delay on for the power amp or separate it's power on from the stock stereo. The idea is to turn on the stereo with the Sony off and after a second or less, a manual switch or a delay activated switch will turn on the Sony. The idea is to switch on the Sony after the thump has finished. Good luck and hopes this gives you an idea. Pls post back how things turn up. Kind regards.
Aug 15, 2007 | Sony XM-2002GTR Car Audio Amplifier
PPI PCX-280 Car Audio Amplifier Logo
268 people viewed this question
Top PPI Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
