Averatec laptop 2300 need free reboot I must copy it on a disc and then put it in my laptop
  • mike12775 Apr 08, 2009
    Just researching my problem and I came across this posting. I am locked out of my averatec 2300 series laptop. I deleted all but one user account (an administrator login) and it wont let me log in without a password. I tried Petter Nordahl-Hagen's http://home.eunet.no/~pnordahl/ntpasswd/
    downloaded from another computer and i cant seem to get the disc to boot. Any other cures or hints or links would be super. Thanks in advance, Mike
  • BJ1957 May 11, 2010
    I have no idea what you are trying to say. Please have someone who speaks English better clarify. No offense intended: English is a difficult second language.
I need to find the recovery disc (3) for my
You may be lucky enough to find them on ebay. If not just use a regular Windows OS disk and then download the drivers from Averatec: Click here for the link: http://www.trigem.com/us/support/drivers.asp
Mar 17, 2010 | Averatec 3200 Series Notebook
HOw do I take out old keyboard Averatec 2300 I need to repair cannot type key before n
With a flathead screwdriver around the left-top top-left top-center top-right and right-top you will see a 1mm thin plastic bar. Simply push all of them in and the keyboard comes straight out. To put it back in simply put the keyboard wire into its slot and then push the keyboard down with minimal force so it will snap back into place. A bit late but for the future!
Nov 07, 2009 | Averatec 2371 AMD Turion Notebook
Wireless driver download
I just used winzip and opened the driver. I see the driver and its there. Do you have a copy of winzip. if not I will give you a link to version 10 which is free
Apr 28, 2009 | Averatec 4200 Notebook
Need recovery disc for averatec 3200 i can not restore computor
googled the manufactor for the recovery disc, the r sending me one for free..
Dec 12, 2008 | Averatec 3200 Notebook
Averatec 3150hd-01
Yes, you should instead use a windows installation CD or DVD in that case.
Jun 27, 2008 | Averatec 3150H Notebook
Averatec 2300
My 2300 started same problems in Dec 08 (almost 2 years old) Its an overheat problem! With black screen the two blue lights an bottom left are on. Leave powered up and in an hour or so will shut down on its on, then will start back up normally but shut down again in about an hour.Correction 1. pull off back cover, blow out the dust. 2.Go to set up (F2 on power up and run fan cal) 3. Take the back cover off you will feel how hot the CPU and hard drive are that is because vents are too small for an aging laptop. Now take the cover and drill a double line of holes on each side of the hard drive vents, Next over the CPU (where the fan blows in air, drill a triple line of new vent holes in the cover). A 5/32 drill will be about right. You may also wish to purchase an inexpensive Belkin laptop cooler. About $19 at Best Buy. This solved my problem as I do like this little one for travel
Glenn New Mexico
Jun 22, 2008 | Computers & Internet
Averatec 2300 laptop will not power on.
We need to determine if the problem is your graphics chip or if the laptop really isn't booting. Do you get any kind of hard-drive activity light when you boot it up?
May 13, 2008 | Averatec 3200 Notebook
Acer 2300 travelmate laptop
Try this:
  1. Press Windows Button & Pause/Break to go to the System Properties (or right click on My Computer and choose Properties, but the other way is more fun.)
  2. Choose Device Manager.
  3. Expand the Universal Serial Bus controllers section
  4. Right click and choose Properties of one that says something about PCI bridge (I forget the exact name and after you fix the problem, this item goes away. If you aren't sure, you try step 5 and 6 on all of the USB items in that list.)
  5. Click on the Driver Tab (it's kinda slow loading).
  6. If the driver information on top says "Not found" or "Not installed" then click Update Driver... and let it look for the driver itself (I didn't need the XP CD but that might be because I keep a copy of it on my hard drive just incase. You might need it, I don't know.)
  7. After it finds the driver, click Okay and USB should start working immediately - no reboots needed!
May 05, 2008 | Acer TravelMate 2300 Notebook
Missing cd rom driver for averatec 2300 laptop
you can get driver from this here: http://www.averatec.com/customercare/downloads.asp
Apr 27, 2008 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
