Question about Maytag Dryers
I have an electric maytag, only 2 yrs old, model #MDET446AYW. It quit running. The green light comes on but when you push to start nothing happens??
  • Maytag Master
  • 3,361 Answers
Replace your thermal fuse.
Posted on Mar 03, 2009
Single mother of four wash machine not working only 2 yrs old.
Take off electricity wire, Open the filter from the front( maybee need to remove a rectangular cover.) turn the filter anti-clockwise. take out the hairneedle or coin. (the water will come out from the filter so make preparation with towels., see inside the filter if something is stucked around the small propellar. Turn the electricity back on. choose for example pumping program or centrifugeprogram. After that the machine should work.
Jun 01, 2013 | Whirlpool Washing Machines
Gas dryer will not start. Model MGDB850WR0 maytag bravo gas dryer serial MY3101043 purchased 2009. lights and display come on, push buttons give tones, but nothing happens when you push start. Display...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2011 | Maytag Dryers
Dryer has power - we can hear the timer ticking and the light comes on when the door is opened, but when we push the start button nothing happens model # leq9558ko 8 yrs old electric
does the light close when the door is closed??? poosible that the door switch has gone bad. or a bad thermal fuse behind the unit is also a common culprit of this.. its a white thermostat on back of unit behind the panel (-----------------------) approx this long ad white,,
Oct 13, 2010 | Whirlpool LEQ9858P Electric Dryer
Maytag dryer does nothing
could be a bad motor start cap,defective door interlock switch
Oct 28, 2009 | Dryers
I have an older Maytag D8512 with an electric igniter. When I push the start button, nothing happens. I checked the pilot light and it is off. I used a long matchstick to see if I could start the pilo
there is no pilot light. electric igniter will glow and pull amps allowing gas valve to open. if you do not see igniter glow it is bad or thermal fuse has blown. look for 120 volts at the igniter when running. if voltage found bad igniter, if no voltage trace back to fuse/stats.this assumes dryer is actually running. if drum not turning could be a number of things. door switch, fuse, etc
May 24, 2009 | Maytag Dryers
Won't run
ensure your door switch is working then move into timer.
May 05, 2009 | Roper RES7646KQ Electric Dryer
Maytag mdet446ayw runs a few seconds and shuts off
maytag dryer mdet446ayw runs for around 30 seconds then shuts off
Apr 15, 2009 | Dryers
I have a very old roper dryer (11 yrs), it quit mid cycle. It ticks when I set the timer but nothing happens. The on button quit along time ago but when you shut the door it would start. Today nothing...
You've got an open circuit somewhere in the loop betwixt the start button, the "safety" button actuated by the door, and the motor/heat coils. Trace out those circuits and you'll have that thing running in no time.
Feb 27, 2009 | Roper REK2950W Electric Dryer
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Dryers Logo
212 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
