SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
SOURCE: E-04 Clear Paper Jam, no paper in printer
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
SOURCE: My Epson LQ-590/LQ-2090 keeps having paper jams
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
SOURCE: Epson print LQ-590 always paper jammed at roller
the paper you are using may be moisten. pls try another paper sheets . purchase new papers.
if the problem continue clean the paper feeder assembly roller with moist cotton using cleaning liquid eg petrol or spirit etc.
SOURCE: paper jam message does not clear
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takiqq14
