Question about PPI PCX-280 Car Audio Amplifier
As soon as i turn the amp on it goes into protection mode (red led) even when nothing is plugged into it except powers and grounds
  • Ryan Lee
    Ryan Lee May 11, 2010
    check for shorts
  • 61 Answers
Make sure the remote wire from the deck is in the amp but move your ground wire to a new solid metal location you may have to scrape the paint surface where the ground is going to go but it will stop protect mode and run properly (make sure to bolt it down by its self no other wires just the ground from amp) also make sure the ground wire is bigger than the power wire
hope this helped
Posted on Mar 04, 2009
Red power/protector light
The amplifier has gone into protect mode and will stay in that mode until the cause is corrected.
Nov 17, 2013 | Sony Xplod 800W Class AB Bridgeable...
I wanna supplied my Amplifier Lanzar MNX 250 with an 12V - 30 Ohm battery, but the led of my amplifier is red and my speaker doesn't play music. How can I fix the "protect mode" in which the...
  1. The battery is 12 volts and Ohms has nothing to do with your amp installation.
  2. Was the amp running and got hot? Many times an amp will go into "thermal mode" when used for an extended amount of time and need to cool down but I assume if you are trying to hook it up you were not using it.
  3. You need to check the ground wire real well. A loose ground will cause protect mode.
  4. Recheck the speaker wires and their connections. If they cross this to can cause protection mode.
  5. This is a 4 Ohm amp, are your speakers 4 ohm or lower> If not then you may be running to low of a load to your amplifier.
  6. I always remove everything from the amp first and power it on and then add wires and see where which connection throws the amp into power mode.
  7. Check the fuse as well but if the LED is on chances are your fuse is good.
  8. If you check all of the items I listed and the amp still goes into protect mode then your amp is bad.
Regards, Tony
May 05, 2011 | Lanzar MNX250 2Channel Car Amp
I just got my PPI dcx 300.2 amp back and i hooked it all up, and connected the fuse back in and started the truck, the amp turns on but the red light starts blinking and says clip out. The amp doesnt smell...
Are you sure everything is correctly connected. If you are running the amplifier in bridge mode then take note that the load to the amplifier can be no lower than 4OHM. dreamsystems
Feb 25, 2011 | PPI DCX-300.2 Car Audio Amplifier
AMp does not display any LED read out
Amps have a part inside that is made to keep the channels equal. The problem is that when there is nothing hooked up to the second channel, then this goes bad and goes into protect. It is really hard on an amp to use just one channel.
Sep 26, 2009 | Bob Mackie Mackie M-1400i Power Amplifier...
Where can i get a free copy of schematic diagram for amplifier
Generally a "protect" mode would be triggered by a shorted output (speaker). I would suggest disconnection all of the speakers to see if the red light goes off.
Mar 16, 2009 | Car Audio & Video
have you checked your speaker connections and any other connection for shorts or multiple ground loops. cause that will definately cause the protection mode.
Mar 03, 2009 | PPI PCX-280 Car Audio Amplifier
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 10, 2008 | Car Audio & Video
How to change the Red Protect light to Green Power.
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Sep 21, 2008 | Audiofonics ADF-240 Car Audio Amplifier
LED Light is on, but no sound from sub at all.. Have double backed on all wires but still nothing! HELP!!
if you change amps and it goes on protection the speakers are blown causing the amp to protect try changing speakers
Mar 24, 2008 | Car Audio & Video
Problem in ppi pcx-2400
Check the amplifiers fuses. Some amps have speaker fuses that leave the LED on if blown. Check for continuity on the voice coils of both subs. Check for 12 volts on the remote turn on line from your receiver. If all of the above are good, the amp is probably toast.
Jul 15, 2007 | PPI PCX-2200 Car Audio Amplifier
PPI PCX-280 Car Audio Amplifier Logo
219 people viewed this question
Top PPI Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
