Question about Motorola Mobility H500 Headset
I NEED THE ORIGINAL PASS KEY FOR THE H500 BLUETOOTH HEADSET
  • irbeau Mar 08, 2009
    I have tried the passcode of 0000, and 1234, and those failed. I am trying to connect to a pantech.
  • Anonymous May 17, 2009
    how to install a motorola h500 bluetooth to a att nokia cell.
    Thanks
  • 3 Answers
Try entering only three 0s. That worked for me.
Posted on Mar 23, 2009
Cant remember numeric passkey for motorola h500 bluetooth
Well the default pass key for most of the headset's is 0000 so you can try this ...........
Good Luck!!
Jun 10, 2010 | Motorola Mobility H500 Wireless Headset
Pass key help
it should be 0000
if not try
1234
4321
6789
9876
hope this helped
please rate well.
Mar 06, 2009 | Motorola Mobility H500 Headset
Pass code bluetooth
The passkey for the Moto H700 is 0000, four zeros. Try removing the bluetooth device, and re-adding it
Dec 22, 2008 | Motorola Mobility H500 Headset
MY BLUETOOTH FOR MOTOROLA H500 I LOST THE PASSKEY AND I USED THE DEFAULT PASS KEY AND IT SAID FAILED TO CONNECT
The passkey is default set for all Motorola headsets at 0000. try that. If this works, be sure to rate the solution. Thanks!
Nov 08, 2008 | Motorola Mobility H500 Wireless Headset
Problems With Pairing H500 and Motorola V190
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 24, 2007 | Motorola Mobility H500 Wireless Headset
I have a problem with my bluetooth H500
You need to full charge both units first before to try them again. YOU MUST KNOW ONE MAIN KEY HERE IS THE BLUETOOTH HEADSET MUST BE IN PAIRING MODE WHICH IS MEAN THAT THE LED MUST IN STANDING MODE NOT IN FLASHING MODE AND WHEN THE LED OF THE BLUETOOTH HEADSET IS IN STANDING MODE, BRING IT CLOSER TO YOUR PHONE AND BE SURE YOUR PHONE BLUETOOTH FEATURE IS ON AND BE RECOGNIZED FROM OTHER DEVICES. Try to restart carefully step by step each device as described above and then if you still can not get them pairing then either on eof them has Bluetooth function impaired. You need to have another Bluetooth Headset to test whether your phone Bluetooth function or the Headset has it. Good Luck
Mar 30, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Headset Logo
595 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
