Question about Verbatim 160GB USB FireLite: The "drive for perfection" is built into our line of FireLite portable external ... 160 GB Hard Drive
External hard drive does not display icon in My Computer
Although this Verbatim Firelite 160 GB external hard drive will show up if I click on the "Eject Hardware" icon, it does not show up in My Computer, therefore I am unable to locate this driver in order to save anything???? Please help.
  • michaelkearn Mar 03, 2009
    It is brand new. I am just now trying to install it.
    My operating system is Windows XP.
  • 21 Answers
Try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Posted on Dec 06, 2012
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Turn the computer off without the external hard drive being plugged in.
plug the external hard drive in a usb port, power up, the systems post boot up will find the drive and inform windows what hardware is installed.
When windows boots up, it will look at all the hardware and find the external hard drive, when windows finishes booting up you should be able to see the drive in my computer.
If you can't access your files,data recovery software can help.I used this one called Tenorshare Data Recovery to retrieve files off crashed HDD and it worked.
If needed,you can download it and scan your hard drive to preview whether your files can be recovered. BTW, you can get it from
Data Recovery for Mac OS X
Data Recovery for Windows OS
Remember: Do not save your recovered data onto the same externalhard drive, otherwise the files you want to recover may be written over.
Posted on Jun 15, 2012
  • 4 Answers
1. Is the Verbatim brand new ?? Have you been able to use it in
in the past ?
2. What is your OS ?
Posted on Mar 03, 2009
  • dennisgk46 Mar 03, 2009
    I had a simliar problem. This is how I fixed it in XP;
    Remove any attached external devices except the one having the
    problem.
    Go to:
    1. Control Panel
    2. Administative Tools
    3. Computer Management
    4. Under Storage right click on "Disk Mangement"
    5. The bad drive should show up as Disk 1 with a black bar across
    the top.
    6. Right click on the bar.
    7.Select " change drive letter and paths " and follow the instructions.
    8. If number 7 does not work, go back to the menu and select
    "Format". During the FORMAT I believe you will be asked to assign
    a drive letter.
    9. GOOD LUCK
    I acutally had this problem with two different drives. I fixed the first one using the instructions above. But the second drive didn't even show up in Disk Management. I had to return it for a new one.
I do not see my external drive
if it doesnt show you external drive try changing the cable which connects the drive to the pc
Mar 16, 2011 | Verbatim 160GB USB FireLite: The "drive...
Hi! I stored files, docs, and pics, on my Verbatim Ext. Hard Drive USB 2.0 awhile back. I now want to update it. When I go to "shortcut to Verbatim" I get a Nero BackItUP Archive File page. When I...
Connect the external drive.
Open 'My Computer'.
One of the icons should be associated with the external drive.
Double-click the icon to "open" the external drive, to show the files/folders on the drive.
Oct 05, 2010 | Verbatim External, USB 2.0, 750GB...
I CONNECT EXTERNAL HARD DRIVE TO PC WITH XP AND IT DID NOT RECOGNISE EXT HARD DRIVE HELP PLEASE
dear sir
good day
try to replace the USB cable and test the Hdd on an other computer system to make sure it is function and good luck
Dec 29, 2009 | Verbatim 160GB USB FireLite: The "drive...
Need drivers
Below is the link for the FireLite 160GB portable HD. Drivers are only needed for win98. 2000/xp/vista are plug and play. The manuals are included at this link.
http://www.verbatim.com/support/support.cfm?part_number=firelite+160gb+usb&x=56&y=11
Additionally, there could be a problem with power supply. A switch is on the back...USB or EXT. EXT is for an external supply. (http://www.verbatim.com/products/detail.cfm?product_id=38819801-1143-3415-5FE3682C49A8E37F&cat_id=3883B708-1143-3415-5FB9F3C74069A098) USB is naturally for a USB cable. Clicking might indicate low power when using USB. Switch to the external adapter or get a USB cable with two connectors for the computer (the extral cable draws more power),
good luck.
Jul 10, 2009 | Verbatim 160GB USB FireLite: The "drive...
Verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Jun 09, 2009 | Verbatim 160GB USB FireLite: The "drive...
New verbatim 160gb usb external hard drive model # USB160 isnt recognized by my pc.
problem.
Go to:
1. Control Panel
the top.
a drive letter.
9. GOOD LUCK
Nov 21, 2008 | Verbatim 160GB USB FireLite: The "drive...
Verbatim firelite external hard drive
ok...well...then if it is compatible with your current operating system, then it should work. is this a first time install?
Oct 13, 2008 | Verbatim SmartDisk Firelite Portable USB...
Verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
May 26, 2008 | Verbatim 160GB USB FireLite: The "drive...
Verbatim 160GB USB FireLite: The "drive for perfection" is built into our line of FireLite portable external ... 160 GB Hard Drive Logo
905 people viewed this question
Top Verbatim Computers & Internet Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
meteshadow
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
