Question about Epson ACULASER CX11NF All-In-One Printer
G'day, I have an Epson CX11NF model No. KBB-2bb, and unfortunately the automatic paper feeder is not working. All suggestions re repair or where to buy replacement part in Australia appreciated. Cheers Tony hderosas@optusnet.com.au
  • 513 Answers
This your place Buddy, this is the website where you order parts in austrilia and i will send you the trouble shooting manual for this machine.
http://tech.epson.com.au/
Best Regards
Posted on Mar 03, 2009
    Sergeant:
    Novelist:
  • 277 Answers
You can get the replacement parts at local printer reparing shops as the company does not supply spare rollers you will have to buy whole unit.
. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
  • Epson Master
  • 19,396 Answers
Did you try fixing the paper feeder first?
Paper jam
Epson stylus paper feeder keeps jamming
Feb 16, 2014 | Epson Stylus Sx535wd
Automatic Document Feeder
turn it OFF then locate the cable that is connecting the ADF and the main FLATBED scanner. Disconnect and re-connect it.
Oct 09, 2008 | Epson ACULASER CX11NF All-In-One Printer
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Epson 3810, paper will not feed, no paper jammed in printer
Paper feeder problem. Distortion of pick up rubber in paper feeder or loose of thickness. Take to Epson service center for replacing it. Or if you have experience in disasembling and asembling printer, you can repair by add thcikness pickup rubber and rearrrange position of the rubber. Also check lubrication of paper feeder mechanic.
Aug 19, 2009 | Epson Office Equipment & Supplies
Auto Document Feeder copier problems
The scanning glass probably needs cleaning.
Jul 31, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epsoncx11nf doc feeder inop
This is usually caused by the grey cable connecting the ADF to the scanner unit. A wire inside often breaks and the cable requires replacing by a technician.
Feb 03, 2009 | Epson ACULASER CX11NF All-In-One Printer
ADF Jam... Service req c2011
Can be a tough one.
1st - Open the ADF & make sure that the 2 little Sensor tabs move freely.
2nd - Lift the ADF & check that the White Plastic Paper Guide is "down in the slot" & not resting on edge of the white flat bed scan pad or overlapping the scan pad.
For some C Error Codes
Check for electrical interference from external devices.
Disconnect the Printer from all devices, and run a test print..
Here are the "c2011 error" fixes per the manufacturer:
Replace the Automatic Document Feeder.
Replace the Scanner.
Replace the Main Board.
You might try unplugging the ADF & see if you can operate without it.
If you unplug the scanner, the printer might not function.
Jan 27, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epson cx11nf paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Epson ACULASER CX11NF All-In-One Printer
I have a Print Error Paper Set LT
check paper settings and change it to automatic
Access the printer driver, click the Basic Settings tab, and select Auto Selection as the paper source. Then click OK
Mar 31, 2008 | Epson ACULASER CX11NF All-In-One Printer
Won't print but copies and scans
What operating system and is this on a network as a shared printer or wireless?
Download Epson net config from the website and run the program on all computer and configure it, make sure on the printer that ip is set to obtain automatically.
try this link as well
http://files.support.epson.com/htmldocs/cx11nf/cx11nfug/dwnh_7.htm
Jan 16, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
