Question about Creative Labs Computers & Internet
Distorted sound after installing software plus GigaPocket issues
I've recently bought myself a set of Logitech Z5500 5.1 surround sound speakers for my PC and also an external USB Sound Blaster X-Fi 5.1 sound card as my PC currently only has a built-in OEM sound card.
I managed to set up the speakers as per normal, and the sound card works great, with a few exceptions.
Firstly, I initially received the expected sound from the speakers when I first wired them up, but as soon as I installed the software, the output was distorted and crackly and I had no idea how to get the levels back down to normal. However, I had just reformatted my PC and was only running XP SP1, so perhaps the problem could be the fact that I did not have SP2 installed...
I had no idea how to correct the distortion, so I reformatted my PC again and started from scratch, but didn't install the software this time, and so far the speakers seem to be working fine, albeit without the benefits that the software has to offer.
I have since reinstalled Service Pack 2 for XP, but i'm reluctant to install the Sound Blaster software in case I experience the same problem again and lose the use of the speakers - As they are currently working fine, I do not really want to take the risk
My second and perhaps more serious problem is that my built in TV card doesn't seem to want to work with this sound card. I have a Sony Vaio RZ504, and the TV card comes built-in as standard, but for some reason it only outputs sound via the built-in sound card.
The Sound Blaster USB sound card seems to be missing a crucial volume setting which the TV card is reliant on - I am not sure if there are any updates available for the Sound Blaster software drivers, but this seems to be a very serious issue as my GigaPocket software doesn't seem to have an option to choose output sources, and as a result I am unable to watch / record TV, or play my consoles through the A/V connections as I have no sound
  • 4 more comments
  • G3M-PH0 Mar 03, 2009
    No, I have not disabled my onboard sound card. How would I go about doing so?
    So far the only program that I have found that isn't working with the new sound card is the GigaPocket software which runs everything from the TV card
    My PC remote control also no longer controls the volume at all, and instead I am forced to use the volume control for the Z5500's, but I can live with that
    A list of my hardware specs can be found here:
    http://support.vaio.sony.co.uk/tutorials...
    Ok, no, I have never accessed the BIOS in this manner.
    I had already entered the Device Manager though and disabled the onboard sound card (This was my initial thought and the first thing I did), but this has not fixed the problem
    The GigaPocket software seems to play saved recorded data fine, but not direct through either the coaxial or A/V ports. However, if I set the onboard sound card as the default, and reccord something with this software, I can then play it back with sound through my new sound card... But of course, this is not really suitable for watching television or playing a game etc
    Correct, it was F2.
    I've disabled the sound card completely, but doesn't seem to have solved the GigaPocket problem, although the USB Sound Blaster is now the only selectable sound card on offer
    The sound is definitely being input, but just isn't being output - At least, not through the desired sound card. It seems that the GigaPocket software will only work with the OEM sound card
    Any drivers for the Sound Blaster must have been loaded automatically as I haven't installed anything from the disc for fear that it will corrupt and distort the sound again as it did the first time. I have no idea whether there is anything within the supplied software that overcomes the problem of having no sound with certain programs, but seems a bit strange that there are only three volume control settings for the Sound Blaster compared to at least eight for the onboard sound card...
    Here is a comparison between the two:
    http://img25.imageshack.us/img25/4315/su...
    http://img21.imageshack.us/img21/8347/so...
    As you can see, the Sound Blaster has no master volume, no line in, and no mic input settings, so i'm wondering whether these could be included on the supplied Cd Rom... However, without knowing why I received distorted noise before, I don't really want to take the risk at this time until I know a little more about it
    I do have a digital optical port on both the Sound Blaster and the surround sound commander, as well as one built into my onboard sound card on my PC. Although, I don't have an optical cable long enough to connect any of them together. But I do know what you mean about the lack of a physical line out
    And just to clarify, this is the Sound Blaster I am referring to:
    http://www.soundblaster.com/products/pro...
  • G3M-PH0 Mar 04, 2009
    I recently stumbled across the following webpage which is an update for the Giga Pocket software:
    http://esupport.sony.com/US/perl/swu-dow...
    Although it seems that the site is of American origin and only intended for certain American sold models, as detailed in the following list, of which my model (RZ504) is not included:
    http://esupport.sony.com/US/perl/swu-mat...
    However, one thing did catch my eye - The sentence on the page which states:
    "Enhances compatibility with the Microsoft® Windows® XP operating system Service Pack 2."
    Now this has me thinking that perhaps SP2 is the problem here and not either of the sound cards. After all, everything was done at roughly the same time, so I have no way to distinguish what single factor may have caused the Giga Pocket software to cease functioning normally. As I didn't test it out with SP1, it could well have been the installation of SP2 that broke it... I am also guessing that this is just one such example of Giga Pocket being incompatible with SP2
    The question is, if this update software exists for certain US models, then surely there should also be a similar update for UK spec models, including my own.
    I already know of at least one update which fixes a problem with the timer recording manager and DST, but can't seem to find a full update for the whole software
  • G3M-PH0 Mar 17, 2009
    I contacted Sony via eMail well over a week ago and have yet to receive a reply, which means they're either ignoring me or just don't know how to solve the Giga Pocket problem.
    It's frustrating,a s one of the main reasons I bought this computer was because of the Giga Pocket feature and the ability to watch TV through the computer and attach my consoles to it, but now that's not possible without experiencing a loss of sound due to upgrading my sound card. One would think they would be aware of such issues and upgraded the software, or at least released a newer version which supports other sound cards
  • 447 Answers
Have you physically disabled the onboard sound in the BIOS? By doing this I think most of your other hardware/software would default to the only audio device (your SB).
Post back if you've already done this and I'll see what else I can dig up on your hardware and possible conflicts.
Posted on Mar 03, 2009
  • 3 more comments
  • John Elliott
    John Elliott Mar 03, 2009
    Have you ever had to go into the BIOS or setup for your machine?
    Different models have different keys which allow you to enter BIOS - sometimes del or f2 or f12 or even hitting the esc key to access a boot options menu. You may find info on which in the user guide for your machine.
    Once in the BIOS go to the integrated peripherals and find the onboard sound, hopefully there is an option to disable it.
    You may even be able to accomplish this within the device manager in windows by opening the Sound, video and game controllers section and disabling the sigmatel audio device (right click + disable).
  • John Elliott
    Consult your user manual on how to enter the BIOS for your machine, let's try to physically disable the onboard audio in your unit to be absolutely sure there is no conflict.
  • John Elliott
    I believe you use the F2 key on boot to access the settings.
    Look for an entry for integrated peripherals (or something similar to that title) and see if you can't disable the onboard audio.
  • John Elliott
    Now that the onboard audio has been disabled in the BIOS we may want to try to reinstall the SB drivers (not necessarily the added software although you may want to give this a try also).
    I did spend some time going thru the support docs for both pieces of equipment (as I know you have) and as you've pointed out - there's just something missing here. One would hope that Sony would address this problem (as my impression is that it would require an update or patch to deal with the TV card audio).
    I wish there was a better answer for you but without a physical line out (and into the SB) and no way to "redirect" the sound output I'm not sure there's much we can do here...There is however an additional setting in the SB driver for Digital Output Only (detailed on this page (located under advanced settings)), toggling/disabling this and testing might be something you want to try.
  • John Elliott
    John Elliott Mar 17, 2009
    I can definitely feel for you, I've setup a similar media system (albeit an aftermarket add on) with my satellite system. When one has the hardware integrated out of the box one would expect the stuff to work with just about anything external, especially when it's name brand.
    Hopefully Sony will get back to you soon and perhaps release an update for your unit that takes care of that...
Hi, I bought recently a new 5.1 Surround Sound System Logitech X-530 and want to connect it to our new LCD LG 32LD450 HD TV. The LG TV has apart from all Digital, Optical and RCA Connections as well one...
You can't connect the speakers to your TV. I doesn't have any audio output available, just inputs. Those are for connecting the audio from sources like DVD players, and they go in to the TV's sound system. But there's no way of getting the sound out except through the set's internal speakers. The surround system you got is great for a computer, but it's not what you need for TV use.
The only solution I can offer is the suggestion that you invest in a home theater receiver. You can get decent basic systems with the receiver (often with DVD/audio CD playback capability built in) and surround speakers at reasonable prices. Then you use that to drive the speakers, and use the TV just as a video monitor. Then you will have surround sound.
Jun 01, 2011 | Logitech X-530 Computer Speakers
I am currently on Windows 7 Ultimate and I have surround system of Logitech X-530 and the front 2 speakers a playing sond how do I solve this to make the other work as well? Additional information: I also...
Hi...hard time with your logitech Speaker., do you have a 5.1 sound card install inside your pc, like 6 outputs and two input jack on your sound card... a pro sound card to make your logitech X-50 work like a charm if you dont have... I suggest to by a creative soundblaster pro 5.1, but if you do have a surround sound card with 6 input jack install in your pc and fail to work properly...ride down the model of your sound card and check if it compatible with windows 7., just download the patch for it... good luck.
Nov 02, 2010 | Logitech X-530 Computer Speakers
Legitech x-530 support
The quickest way is to reinstall but first uninstall , reboot then install disk and disconenct speakers otherwise a setting may still be active. Regards GeWiz.
Jun 15, 2009 | Logitech Audio Players & Recorders
Z5500 : No Vocals Coming in 5.1 Movies
The same thing happened to me and i just had to reset the system by turning it off and then holding input+settings for like 5 seconds until it shows what firmware version you've got it meqans it's reseted and that should solve your problem.
Apr 03, 2009 | Logitech Z-5500 Computer Speakers
I have dell computer and i bought the logitech X-5.1 SURROUND+SUBWOFER from ebay, byt it didnt come with instructions on how to hook them up, i have it set up with all the right colors on the plugs,but im...
take a look at this site might of some help to you?
http://www.logitech.com/index.cfm/support_downloads/&cl=gb,en
if not get back to me with the model number
Mar 07, 2009 | Logitech X-530 5.1 Surround Sound...
Not all speakers work
http://www.logitech.com/index.cfm/439/3549&cl=us,en?WT.ac=sc|downloads||dd
Jan 13, 2009 | Logitech X-530 Computer Speakers
Logitech Z-640 installation disk, I had to bring my computer back to factory settings and I cannot find my installation disk for my logitech Z-640 surround sound. Is there a place i can download the...
The Logitech website under the support section. All you need to do is look up your model # and then download the software/drivers for the operating system you are using. Hope this helps.
Jan 10, 2009 | Logitech Z-640 Computer Speakers
Logitech Z-5500
Well you have some options, you can either live with 2 speakers and change the settings back to default. Im assuming the colors you have are orange black and green. black= the surround sound speakers. orange= center and subwoofer. green=right left front
Now if u want true surround sound then you need to buy a new card that had all the ports for your speakers.
Oct 21, 2008 | Logitech Z-5500 Computer Speakers
Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Apr 16, 2008 | Logitech X-540 Computer Speakers
Surround sound distortion
Receivers like this will incorrectly decode rear channel audio and pass it on to the rear channels as distorted audio. Make sure the source being used really has rear channel information encoded into it. It could have other issues but check this first.
Dec 16, 2007 | Sony STR-DE625
Computers & Internet Logo
208 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
