Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Aqualink controller reads 6700 REV C and all lights are on ?
  • suemtn1 Apr 06, 2009
    We are having the same exact problem - did you find anyone who could tell you what is wrong
    Top Expert:
  • Jandy Master
  • 7,200 Answers
Shorted controller wires
Posted on Jan 30, 2016
5 Suggested Answers
CNC65
  • 15 Answers
SOURCE: Jandy Aqualink - Rs, button control red lites on contriol panel
HAVE YOU HAD ANY LIGHTNING STRIKES?
Posted on Nov 06, 2008
SOURCE: Why am I getting a 6700 REV C message on my AquaLink RS6 home spa
I had the same issue, but only after I pressed the reset button on the side of the panel. After a couple of days of troubleshooting, I found a small nick in the wiring from the outdoor unit to the indoor paneI. I turned off the breakers to the pool equipment, rerouted a new cat5 cable, but cat3 will work just as well, wired it up and all was good. A local pool guy wanted to charge me about $2000 to replace both units. I spent less than $5.
Good luck
Posted on May 28, 2009
  • 246 Answers
SOURCE: After lightening strike, Aqualink control panel
ok check all the braker even the one for the house .turn them off all and back on if this do not fix check for 220 v if voltage is present the board is bad need replacement get the number from the back to check for prices
Posted on Sep 13, 2009
  • 84 Answers
SOURCE: On Jandy Aqualink RS display it says 6700 Rev C
If you bypass the 4 wire cable wire as described by 'the californ', and the problem persists, there is a problem with the control boards. Either the PowerCenter board or the RS remote board. We see this failure alot. It is usually due to a a problem in the RS4/6/8 electronics but in some cases it is the PowerCenter. They can be repaired at a fraction the cost of new at www.fixyourboard.com. You can send the remote unit first since all the pool functions will remain and they can test it for you. If it is ok, you will have to send the PowerCenter.
Posted on Nov 01, 2010
Display panel shows 6522 Rev HH
check wiring to controller either wires touching at plugs or wires cut
Sep 11, 2012 | Jandy Aqualink Rs4 One Touch Control...
Blue haven bh6100
wire to the house controller has been cut or plugs at aqualink or controller wires touching if all ok then check controller at aqualink with cheater cord cut some off wiring on inside of cover if still doesn't work bad bezel board
Jun 20, 2012 | Jandy AQUALINK RS TELELINK KIT
Aqualink RS6, 6700 rev c message
check to see if wires are cut or shorted if ok need new controller
Apr 30, 2012 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
6700 rev c, aqualink rs
check fro shorted red pin plugs or cut in wires
Apr 30, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
After lightening strike, Aqualink control panel reads 6700 rev c. All lights on, none work. Outside, power center won't work. No lights. Reset doesn't work. Battery good, fuse appears good. Any ideas?
Sep 05, 2009 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
197 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
