Want to reset password on my c500 compaq presario laptop i bought it from a yard sale and cant get past log in password. i was looking for the bios jumpers and cmos battery.
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
SOURCE: bios password
is there not a jumper on the motherboard to reset bios? you could also try to remove the bios battery (a watch-type battery located directly on the motherboard)
you can flash bios most commonly by downloading the bios update to a floppy, and then booting with the floppy in the drive, but if you do it wrong, the end result will be a very expensive paperweight, hence flashing bios should be a last resort...
SOURCE: Where is the CMOS battery on my Compaq Presario 1210 laptop?
you have to open back side of ur laptop and u can find ur mother board...on that u can see cmos battery...
SOURCE: compaq presario c715nr bios password resetting.
if for notebook im not too sure anyway for pc it should be remove casing cover and remove the battery and look for a 3 pin jumper
SOURCE: removing bio's password
locate the cmos battery, remove it for at least 30 seconds, and reinstall it.
All bios settings should now be reset.
SOURCE: compaq bios password reset
Windows Advanced Options Menu Please select an option: Safe Mode Enable Boot Logging Start Windows Normally Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. http://download.cnet.com/password-cracker/3000-2092_4-10226556.html password cracker free hope it helps
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Safe Mode with Networking
Safe Mode with Command Prompt
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
