GE Profile Spectra JGBP90 Gas Kitchen Range
Problem for GE Profile Spectra JGBP90 Gas Kitchen Range
Oven will not ignite, but broiler and stovetop
By cin0915 on Mar 03, 2009
oven will not ignite, but broiler and stovetop work . How to light the pilot light on the oven??
Same Problem
Apr 23, 2009
-   stove top and broiler work but oven doesn't. Gas kenmore
-   Guest
Mar 28, 2009
-   can't open the bottom pan to oven to ignite the oven.
-   Guest
Mar 04, 2009
-   model jgbs16gep1ad stove and broiler work stove does not work, press bake and start button says pre heat but stove does not start up-   sljped
Mar 04, 2009
-   stove works , broiler works on broiler mode, press brake mode and then start button , shows pre heat on indecator , does not light or start up -   Guest
Best Solution
posted on Mar 03, 2009
Very Helpful)
jsrock516
Rank: Guru  GE Expert
Rating: 96%, 7263 votes
Most modern stoves no longer have a pilot. The problem is more than likely caused by a bad igniter on the bake manifold. The following link explains igniter types and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Modern stoves are equipped with either a glow-bar or spark type igniter. These igniters do become weak with age and fail. This tends to be more common with the bake feature because it gets used more often. If the igniter is worn to the point that it longer produces the correct current potential or spark, the gas valve will not open and you will not have ignition. This is actually a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. Such a condition would be dangerous and could cause a flash ignition or explosion.
If the model number you have this listed under is correct, you can see an illustration of your stove at appliancepartspros.com. Just type in the model number and look under the "Gas Burner Parts" section for item number 28 (part #AP2014008).
If you have questions, or require additional assistance, please post back and let me know. I hope this is helpful to you.
Was this helpful?
Yes
No
4 people thought this was helpful
Popular Solutions for GE Profile Spectra JGBP90 Gas
Questions and Unsolved Problems for GE Profile Spectra JGBP90 Gas
Do you recommend GE Profile Spectra JGBP90 Gas Kitchen Range?
Answer
Answer
my ge xl44 oven is locked, my daughter moved the self cleaning lever on it and its locked, 4 food... (More)
Answer
My left front burner on my GE Spectra XL44 won't ignite unless I light it with a match. It clicks as... (More)
Answer
The top burners are working fine but the oven will not heat. How can we get the oven to come on.... (More)
Answer
xl44 stove, the burners and broiler work but the oven won't turn on.
Describe your Kitchen Ranges problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Range Experts
Top Range & Oven Repairmen
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
