Question about Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array
I want to add more speaker at my paspor fender 500
To do this I need extra amplificador oa just a need to connet some spekers at power amp insert located on the front panel?
    President:
  • 1,138 Answers
Run out of the stereo output jacks into a separate amplifier and speakers. The amplifier send jack only sends signal from the particular channel it is part of. In other words to get all the signals from all the channels you would need another mixer, amp and speakers. It is easier to use the stereo out which will give you all the signals. If you only use left out or right out make note of where your panpot is set for each channel.
Posted on May 13, 2009
Where is the fuse located in a marshall ma100 h amp head
The fuse should be located on the back panel near the power cord. However, there are also internal fuses as well....If the amp is vacuum tube you will also have a HT fuse as wall as a power fuse. If it is a solid state unit then it will have a power fuse.. Hope this helps.....If you need more info let me know....
Jan 16, 2014 | Marshall Amplification Marshall MA100H and...
I tried to plug in a digitech bp200 pedal and then my amp went on the fritz and starterd buzzing loudly. I attempted using the effects loop section on the back of the amp with my bass direct into the amp,...
DO NOT try a guitar pedal as an effects insert via the back jacks... they are for an external line level EQ/Effects type unit. Your guitar pedal should NOT have caused any damage. Check the power adapter you are using with the BP200. The BP200 takes a 9 VAC adapter, NOT a 9VDC type common to most pedals. You cannot use one of the Pedal Train type supplies with the BP200. Also check that you have the in's and out's correct on the pedal... backwards and they will cause what you are observing.. Verify your cables are good. The output of the pedal goes in the FRONT jacks of the amp. ONLY line level drives go to the back jacks.
Jun 05, 2011 | Hartke Lh1000 Bass Amp Head 1100 Watts...
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Can i hook up a seperate power amp . to the pmp 6000 powerd mixer . for more over all power.
You can add extra amps driving ADDITIONAL speakers... you CANNOT parallel amps driving the same speakers.
Drive these seperate amps from the MAINS OUT connnectors using TRS and balanced lines to those external amps.
Aug 19, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
El transistor de poder de mi amplificador line 6 spider ii de 30 watths se quemo, quisiera saber el modelo del transistor para poder cambiarlo
If you want to know what the part number of the power amp in your unit is, it will be either a TDA2030 or TDA2050 which ia a 5 terminal audio amp of 14Watt or 32 Watt respectively.
Aug 11, 2010 | Line 6 Spider Iii 30
Wirings connections from mixer to equalizer to crossover to power amp to speaker
The connections can be accomplished in 2 ways: Direct or using insert cables. The most common way is directly as follows:
Mixer L/R ===> EQ Input L/R ==> Amp Input L/R ==> Speakers L/R
Using insert cables you would have a single 1/4" connector at the mixer end (inserted in to the "insert" L or R) and the other end into the EQ. If you need more details about this method, please post the model of the EQ so I can determine the type of insert cable required.
Hope this helps.
Dan
Mar 14, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
En los amplificadores Line 6 Spider III ¿puedo conectar pedales de efectos que no sean de la misma marca línea 6?
translation: In the amplifier Line 6 Spider 3, is it possible to connect effect pedals of other makes apart from Line 6.
Creo si, pero primo del amplificador con una corda guitarra.
I think that you can, just add them to the input
Jan 23, 2010 | Line 6 Spider Iii 30
I have a 30th special edition,,1962,,1992 marshall amp and want to know how to set up,,has jack plug in back,,not sure where it goes,,??
Well if there is anything you need to insert into the effects loop IE, wah pedals, noise gates etc etc the return is the output of the effect and the send would go to the input of the effect. As far as inputs those are all on the front panel.
Jan 08, 2010 | Marshall Amplification Marshall MG250DFX...
SPEAKER OUTPUT CHANNEL FAULTY, TWO MIKE CHANNELS DOWN
These are a real pain to open. You have to remove the front panel to remove a shield to remove the back amplifier power supply area. The power supply is a switching type and has lethal voltages present. Working on this should be done using an isolation transformer. With your symptoms, it is likely one side of the power amp MAY be blown, but do check that the wiring hasn't fallen off and the jack itself. Two pairs of wires come from the power amp to the front panel jacks. document location of ALL the cables you disconnect as they CAN be confusing to restore.
May 13, 2009 | Fender Passport Deluxe 500watt Sound...
Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array Logo
177 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
