Question about Kenwood KDC-138 FM / AM Receiver
Need to learn how to set time - Kenwood KDC-138 FM / AM Receiver
  • Anonymous Apr 05, 2009
    Did not work!
  • 90 Answers
Do you have the owners manual -- ? you can download one from their website that has the instructions on this function
Posted on Mar 03, 2009
  • mike4671 Mar 03, 2009
    send me your email address and I will send you a copy of the owners manual --
    to set the time::::
    1. Select Clock Adjustment Mode
    Press the top or bottom side of the control knob
    Select the " CLK ADJ / CLCK display "
    2. Enter Clock Adjust Mode
    Press the center of the control knob for at least 1 second
    The clock display blinks
    3. Adjust the hours
    Adjust the minutes
    Press the right of left side of the control knob
    4. Exit Clock adjustment mode
    Press the { B.BOOST} buttom
What is relearn predcudre for idle on 08 chev. 1500 5.3 eng.
Throttle Learn
Description
The engine control module (ECM) learns the airflow through the throttle body to ensure the correct idle. The learned airflow values are stored within the ECM. These values are learned to adjust for production variation and will continuously learn during the life of the vehicle to compensate for reduced airflow due to coking. Anytime the throttle body airflow rate changes, for example due to cleaning or replacing, the values must be relearned.
A vehicle that had a heavily coked throttle body that has been cleaned or replaced may take several drive cycles to learn out the coking. To accelerate the process, the scan tool has the ability to reset all learned values back to zero. A new ECM will also have values set to zero.
The idle may be unstable or a DTC may set if the learned values do not match the actual airflow. Without Scan Tool - Learn Procedure
• DTCs P0068, P0101, P0102, P0103, P0106, P0107, P0108, P0116, P0117, P0118, P0120, P0122, P0123, P0128, P0171, P0172, P0174, P0175, P0201, P0202, P0203, P0204, P0205, P0206, P0220, P0222, P0223, P0300, P0351, P0352, P0353, P0496, P0601, P0604, P0606, P060D, P0641, P0651, P1516, P2101, P2119, P2120, P2122, P2123, P2125, P2127, P2128, P2135, P2138, or P2176 are not set.
• The engine speed is between 450-4,000 RPM.
• The manifold absolute pressure (MAP) is greater than 5 kPa.
• The mass air flow (MAF) is greater than 2 g/s.
• The ignition 1 voltage is greater than 10 volts. Without Scan Tool - Learn Procedure
Important: Do NOT perform this procedure if DTCs are set. Refer to Diagnostic Trouble Code (DTC) List - Vehicle.
Start and idle the engine in PARK for 3 minutes.
The ECM will start to learn the new idle cells and Desired RPM should start to decrease.
Ignition OFF for 60 seconds.
After the 3 minute run time the engine should be idling normal.
Important: During the drive cycle the check engine light may come on with idle speed DTCs. If idle speed codes are set, clear codes so the ECM can continue to learn.
? If the engine idle speed has not been learned the vehicle will need to be driven at speeds above 70 km/h (44 mph) with several decelerations and extended idles.
After the drive cycle, the engine should be idling normally.
? If the engine idle speed has not been learned, turn OFF the ignition for 60 seconds and repeat step 6.
Once the engine speed has returned to normal, clear DTCs and return to the diagnostic that referred you here.
Dec 18, 2016 | Cars & Trucks
How to set base timing on 1999 escalade
The base timing can be set by lining up the timing mark at TDC for cylinder 1 with a timing light. The truck may still run badly because the ECM will need to be set to "learn" mode. This can only be done by a dealer.
Apr 25, 2014 | Cadillac Escalade Cars & Trucks
Need a manual for a procom ventless gas fire place,FBD400 RTCC M MO,wont turn with remote,changed all batterys.
ProCom manuals should be easy to locate since they are still being distributed and sold. Have you already located one? I am uncertain how to load one here but if you have not located one contact me and i'll get a copy to you.
Every time the batteries are changed in the receiver and transmitter the transmitter has to be "re-learned" to the receiver. To do this locate the "learn" button which will look like a tiny hole so you have to stick the end of a pin or a pen in the hole to press the button. Hold the button down until it beeps at you 5 times and release. press the button again and release and then press Any button on the transmitter.
Once the receiver is set into its "learn" function it does not matter what button is pressed on the transmitter because the next signal the receiver picks up will be the frequency it is attached-to.
In order to change the transmitter simply hold the learn button down until it beeps 5 times again which tells us it has wiped out its memory. Then press, release and press the transmitter.
Aug 21, 2013 | Real Fyre 30" Evening Fyre Ventless...
I switched the heating on a week ago and re-set programmes. It was clearly set to come on every weekday at 6.30am but kept switching on at 5.30am. To try to fix this, I tried pressing the reset button but...
Sounds like the original problem which is not truly a problem is that the Adaptive Recovery Setting was set to on which the Thermostat is self learning and if for example you set the thermostat to go to 70 deg. at a certain time it will turn the unit on early to achieve that setting at your designated time, and it will slowly learn and adapt itself to how long it takes to reach that setting from the previous setting. The next issue is that you have actually accessed the installer's settings page and you will need your manual to get out of this.
Sep 23, 2011 | Heating & Cooling
Have a pnosonic inverter which we have tried to set the timer on a number of ocassions only to find the air con starts on its own during the night for example we tried to set it to start at 5:50am and it...
Your thermostat may have a "learn" feature that learns how long it takes to get to your target temperature by the time you set (instead of start at the time you set). To get to the target temp in time, it has to start early. There is no way to turn it off on some units, other units may have an on/off feature for "anticpate", "target", or "learn".
Just bump back the time by 30 to 45 minutes.
Jul 11, 2011 | Televison & Video
I have a AVEX URC-R6 Remote controller that was working fine for almost 3 years with a DISH 722 Reciever/DVR. One morning the receiver IR would receive no signals from either the AVEX remote, or the...
trwck
I have provided instructions on how to save setting on the receiver and remote plus instructions for learning mode. I hope this helps.
Ray Calo
DISH Network
Back Up Remote/Receiver Data
  • Receiver: 222k and 722k
    1. Verify that the customer has an unobstructed LOS and is within 10 feet of the receiver. The customer will need to direct the remote toward the receiver for the duration of the System Wizard setup.
    2. Press and hold the number 0 until the pop-up 380 appears on the screen.
    3. Verify that the System Wizard says the remote is configured correctly.
    4. Select Advanced on the screen.
    5. Select "Backup My Settings Now".
    6. Verify that the purple gem is displayed beside the correct selection.
    7. Select Next.
    8. Select the type of backup to be performed:
      • Full system backup
      • Back up receiver settings
      • Back up remote settings
    9. Verify that the purple gem is displayed beside the correct selection.
    10. Select Continue twice to initiate data transfer. Maintain unobstructed LOS while the green progress bar fills.
    11. Select Continue to resume programming.
  • Restore Receiver Data
    4. Select Restore on the screen.
    5. Maintain unobstructed LOS while the green progress bar fills.
    6. Select Continue to resume programming.
  • Teach Learning Commands
  • Receivers: 222k and 722k
    1. Ensure the DISH Network remote control is programmed to the desired remote address to operate the DISH Receiver.
    2. Place both the DISH Network remote and the original equipment's remote control on a flat, stable surface.
    3. On the DISH Network remote, press and hold the mode button for your equipment for about three seconds until all of the mode buttons light up, and then release it. Your selected mode button will blink.
    4. Select the type of learning you wish to perform:
      • Hybrid Mode
        1. Press and release RECALL, then hold the RECORD button for about three seconds until the mode button is lit again. The button remains lit while learning.
        2. Point the front of the original equipment's remote to face the small square (IR window) on the front left-hand side of DISH's remote. Remotes must be within 4 inches of each other.
        3. On the DISH Network remote, press the button you want to teach.
        4. On the original equipment's remote control, press and hold the button you want learned. If the DISH Network remote learns the command, the mode light blinks off and then back on. If the mode light blinks three times or remains lit, the DISH Network remote did not learn the command. You may need to press the button on the original remote several times for the DISH Network remote to learn the command.
        5. After a button has learned a command successfully, repeat steps 3 and 4 until all commands you want have been learned.
        6. To end the learning sequence:
          • Press one of the mode buttons on the DISH Network remote. This saves all of the commands for that mode and exits learning to return to normal remote control operation.
      • Normal Mode
        1. Press and hold the RECORD button for about three seconds until the mode button is lit. The button remains lit while learning.
  • Mar 25, 2011 | DISH Network ViP722 DTV Receiver /...
    Cant get to the off setup to program timer. the timer wont come on at the set time
    The ST01C is unnecessarily difficult to program.
    And the manual is confusing and unclear.
    I wrote a page to help ST01C users who want specific on-off times (not dawn to dusk):
    http://waterheatertimer.org/ST01C-program.html
    I test and work with timers each day, and I had to fool with the ST01C for an hour or more.
    First thing I learned is how to clear programs and start over.
    Hold down ON-OFF and press reset button with paper clip.
    Next thing I learned is to set programs before setting current day and time.
    That way when you have to reset and start over, you are not re-setting current day and time each time.
    Set current day and time after programming timer.
    Timer doesn't have to be wired into the wall to set programs.
    Here's a tip:
    Program1 is ON
    Program2 is OFF
    Program3 is ON
    Program4 is OFF
    The key is watching the small light bulb icon on display when programming.
    When light bulb is dark, that is ON
    When bulb is is light, that is OFF
    add a comment if you need more help
    Nov 23, 2010 | Intermatic Inc. ST01C Digital In-Wall...
    I need to set up my UPM RCT 100/TR430 remote light control and don't have the instructions. Can you help?
    Press the learn button on the part that plugs in. Then press the "on" button for the remote and it should learn the code.
    May 13, 2010 | UPM Remote Control Timer Set
    How do I program my Jaguar XJR garage door opener?
    Sorry, the process is simple but too lengthy to post here.
    Goto homelink.com
    They make the system and have very complete instructions you can download.
    PLEASE NOTE: MOST but not ALL Brands / models of opener will work with this system.
    Jun 30, 2009 | 2006 Jaguar XJ8
    Need to set time on DEH1700 pioneer car cd player
    Hi!
    Turn the cd changer off and then press the clock button. Time will display. Press and hold down the audio button for 4 seconds. Use the arrow keys to change time. Press and hold the audio key when finished until the time is set as required.
    Do revert for any clarification. Thanks for using Fixya and do rate the solution if found helpful.
    Thanks
    Rylee
    Apr 03, 2009 | Pioneer Car Audio & Video
    Kenwood KDC-138 FM / AM Receiver Logo
    272 people viewed this question
    Top Kenwood Car Audio & Video Experts
    xxxxxx xxx
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
