Question about Toshiba Satellite A100-S8111TD Notebook
Operating system not found
Toshiba Sataellite A100 - comes up Media Test failure, check cable, exiting intel boot agent, Operating system not found -
Start up showing the Toshiba page , blue line goes accross but not all the way ( f12 or f2 does not show uo in the bottom left corner , then it goes in the above messages - I have tryed starting up pressing f2 and f 12 and it still won't allow my to look at any other part -
You help would be appreciated thanks warren
    Master:
  • 404 Answers
Insert system disks and re-install everything again.
Posted on Mar 03, 2009
  • lotfi bouakaz
    lotfi bouakaz Mar 04, 2009
    press f12 (then select CD ROM) makesure operating system disks are in the dvd drive. then it will tell you press any key to boot from cd
    let it load for a while, then click enter to install xp "assume u have xp
    then click enter again, then format and let it do the rest
I have the toshiba protege r705 On start up it displayed: PXE-E61 media test failure, check cable PXE-M0F exiting intel boot agent Insert system disk In drive Why does it do this? What does it mean? How...
your system tries to boot from network. disable the network boot (also called PXE boot) in bios and set your bood media to be your hard disk drive and it should be ok.
Mar 12, 2012 | Toshiba Computers & Internet
I deleted everything on my ibm thinkpadr51, when i turn it on it says initializing but then it says media test failure,check cable. then exiting intel boot agent and operating system not found , how do i...
if you have completely deleted your operating system your note pad will not start as it needs this for instruction you will have to reload/reinstall the operating system
Oct 02, 2011 | IBM ThinkPad R51 Notebook
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
Toshiba portege 3500 tablet saya tidak bisa booting lewat external cd room .. yang ada di layar monitor terbaca : intel(R) boot agent version 4.1.06 copy right (C) 1997-2002, intel...
It means that the BIOS cannot find a disk to boot.
Make sure you selected the hard drive in the boot settings of your BIOS
Remove all external DVD drives or floppy drives or ethernet cables
If you get an error message, you should start troubleshooting your hard drive.
Feb 27, 2011 | Toshiba Portege 3500 Tablet PC
My Toshiba satlelite A105 will not boot up , comes up on screen black says pxe-e61: media test failure, check cable pxe-mof: exiting intel boot agent operating system not found
Go into SETUP (F2, DEL, Cntl-S or somesuch at boot time - or hold F1 key down and force and error and then change your BOOT order to CDROM, HDD. It is Currently NETWORK, CDROM, HDD or the like.
PXE is Network directed bootup, and your LAN connection is waiting or the proper code or instruction or server. You need to turn that off, and BIOS SETUP is where to do it ;-)
Hope that helps
Apr 08, 2009 | Toshiba Satellite A105 Notebook
Errors with thinkpad x31
It sounds like the hard drive may have gone bad in the computer. Can you boot off a cd?
Jan 13, 2009 | Computers & Internet
Toshiba Satellite PC ... Operating System not found
Enter BIOS by hitting F2. Go to Boot tab and change to default boot. I had the same problem and it worked for me.
Mar 03, 2008 | Toshiba Satellite M30 Notebook
Windows won't start
reassemble and check for all
Nov 06, 2007 | Toshiba Satellite A45-S250 Notebook
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
328 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
