Question about Dell (E210882) Motherboard
I have a pcchips m848a motherboard I don't get a signal from my viedo card , i tried 3 prossessers, two viedo cards (agp),two power supplys, the fans work and i get a low quiet beep on start or reset and the hdd sounds like it works for about 3 seconds,the mouse is lit up but keboard has no response (both ps2). no on board graphics, all i can think of is using a pci viedo card to boot up then install agp drivers but i dont want to buy one if i don't have to. any help would be appreciated, thanks Rob
  • 7 more comments
  • RLAMBERT40 Mar 03, 2009
    this is a new motherboard, it says it supports two 184 pin 2.5v ddr 400/333/266 memory, up to 2 gb, i have 2 -1 gb sticks of ddr 400 ram , i tried one , two ,and a 512 stick of ddr333 ,and no ram at all , same result, i am frustrated
    the memory i have is,patriot pc3200 , psd2g400kh ,2gb pc3200 cl3 (2x1gb)kit. and one elixir 512 mb ddr -266mhz-cl2.5 pc 2100u-25330 ,thanks Rob
    yes i also tried this ,no good. wont power on when jumper is in clear position . I think you may be right on the memory, thanks Rob
    I just looked up the specs on my memory it looks like it should work ,any thing else i could try? mabe another prossesser?or bad mother board? thanks ROB
    somthing new i am hearing a high pich sound when i supply power to pc , ( thought it was my monitor) , before i turn it on ,i dont think this is a good sign, Rob
    update: swiched motherboard with msi km400 ,used onboard graphics. now working , then i installed agp card back to same problem, swiched with my other agp viedo card ,no good, installed pci viedo card ,post-boot, xp seemed to work then hanging,and another thing msi board wont shut off,when power is applied fans start ,then i push swich it boots,then windows shuts down and fans still working, going to try pcchips with pci viedo card, very frustrated thinking this would be good boat anchor!
    GOT IT! the pcchips board needs a pci viedo card to post,then swich to agp in bios , thanks to all who tried to help, the hi pich noise was from a fan that soon died, THANKS ALOT , ROB
  • John Elliott
    John Elliott May 11, 2010
    Here are the memory specs for your motherboard.
    Your motherboard uses 2.6v in the ddr 400 variety. Can you provide the part number on the 1gb 400 chips you have so I can cross reference it?
    I know it's frustrating, just need to verify a few things.
    Thanks
  • John Elliott
    That's the type of thing you'd usually get if you had the wrong ram for the logic board (or the wrong voltage ram). Were you using this mobo with the ram before or is this a new addition?
  • 447 Answers
I just recalled an instance where I had to clear the CMOS with the jumper block before being able to post a machine similar to yours.
Check your mobo manual for the CMOS reset jumper location and switch it as directed, power up the machine briefly, power it off, replace the jumper to the original location, power the machine back on.
Did it post this time?
Posted on Mar 03, 2009
  • 1 more comment
  • John Elliott
    John Elliott Mar 03, 2009
    I did another check and I'm starting to think that you would use these Patriot chips (at 2.6v).
    Part # PSD1G400
    Note: This is not my ebay auction so I can't vouch for the seller, etc etc.
  • John Elliott
    I would doubt that all of that hardware could be bad but going over the history of this project you've swapped out just about everything that could be an issue (including the power supply).
    You've probably already done this but unplug all extraneous drives except for the hard drive and the DVD/CD (separating the drives to different channels if they are IDE would be a good idea also). Let's also stick with the onboard video for now until we can (hopefully) isolate what the offending hardware is. At this point I'm inclined to try to use as little of the PSU's resources as possible to see how it reacts. Try to post the machine at this point and post again about the system's behavior afterwards.
    The high pitched whining kind of concerns me, never a good sound to hear emanating from a PC.
  • John Elliott
    Awesome, I'm certainly glad to hear this one got resolved.
How do i disable onboard video on a intel d865glc motherboard?
A couple things to try:
  1. Most important, check with Intel's support site to see if you have the latest version of the BIOS.
  2. Boot to the BIOS: Choose "Configuration", then "Video", choose "Enable if Primary" or if you're feeling brave choose to Disable it entirely. WARNING: DON'T do this until your other card is working properly! You've been warned!
  3. While still in BIOS: Choose "Configuration", then "Video", choose "AGP" if available, or "Auto" if AGP is not an option.
Information from Intel support website.
Oct 21, 2012 | Gigabyte GV-N76G256D-RH GeForce 7600GS,...
Fist sorry for bad english i will try my best ASUS P4P800-VM Motherboard not have video output Singal the agp card that i used dont start fan and make sound so i think it broken or is it a...
Hello
Try using the onboard video chip to run your graphics.This will tell you if the agp card is bad or not.
Remove agp card first.
Also if there is another power supply for agp card fan, try using it.
I have used circut board cleaner on vid cards to get the fan working again with sucsess.
A few ideas.
Sep 18, 2011 | ASUS P4P800-VM Motherboard
Disable onboard graphics of my PCChips M825LU motherboard?
Yes its a BIOS setting that you have to change. Usually you change from on-board to AGP settings or plug the graphics card in, take out the motherboard battery and the power cord from the back, leave it for 20 minutes and put them all back again.
This will reset the BIOS and should auto detect the AGP graphics card. You will however need to set the date and time but you can do that from Windows.
Regards.
Jun 28, 2010 | PC Chips Computers & Internet
Update for SiS 2615 Display Adapter to load windows XP pro
The PC Chips MB PCCHIPS SiS746FX M848A V5.0 462 motherboard does not have onboard video, correct? So if you can obtain the make and model of your video card, you can then find the Windows XP drivers online for download. Then you would be able to provide said drivers when the "system asks you to update SiS 2615 Display Adapter driver"
*Another quick fix would be to use a different VGA card, if you have one available?
*Now, I have never been prompted to update display driver before or during a windows installation or update. So that step I would require a little more detail on. I have only been prompted for mass storage drivers (as seen in screenshot).
Apr 19, 2010 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Have gforce4 ti video card NO PICTURE of any kind screen says no signal detected
The GeForce4 Ti has two rear ports. 1 HDMI and 1 VGA. Try plugging into each. Video signal should be sending out of one of the ports. If neither port is sending out signal than you'll need to trick the bios.
Suggest you remove the Gforce4 Ti AGP card from the MB so you can regain video display and change the settings within the bios. Once you have display, enter the bios menu. Do you have your manual? Enter bios menu by pressing the "Delete" key every 2 seconds until the bios menu loads. Open, Integrated Peripherals, see top of page 3-11. Set Primary Graphic's Adapter to: [AGP]. Than go to the top of page 3-10. Change the AGP Aperture Size to as low as possible or to: [Disabled] "preferred".
AGP 8x Support set to: [Enabled]. Save your settings and exit the bios. The system will restart. Press and hold the power on / off button until your system shuts off. Install your GeForce4 Ti AGP video card. Double check your video card! Some NVIDIA cards need external power above what the AGP slot can provides. Some use a power connector like the floppy drive uses. Other look just like a hard disk drive power connector: 4-pin Molex. If none is found don’t worry about it.
Cheers!
Mike
Oct 22, 2009 | MSI K7N2 Delta2 Platinum Motherboard
Lights and Fan are working, but no beep.
First open cpu cabinet.
Then refix RAM memory.
Pull cmos cell for 10 minutes so all settings of motherbord are defaults.
Then pull porcessor fan and processor clean dust from all chip and parts.
Remove pci cards from pci slot then check.
Let me know if you need more assistanse.
Thanks.
Sep 21, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Graphic card problem
Hi BIOS21, I know this much. I know you're motherboard can not use a PCI-Express video card. You're board can not support SLI. I know from looking & reading the manual for the MSI KM4-L you're board supports an AGP video card. I also know some AGP video cards need extra power for them to function. This varies from card to card. You did find an open power port on you're AGP NVIDA 6600 256MG 128bit card. So plug in the power cord. Every AGP card receives power from the AGP port. Enough to run the fan. Depending on the card it may also need more power provided by the system to function. This is you're case. The power connector would not be on the card if it was not needed. Other AGP cards use the same power cord as a floppy drive. (Just so you know).
Mike
Jun 11, 2008 | MSI KM4M-L Motherboard
PC Chips M848A Motherboard
Try clearing the bios/cmos using the jumper on the board, page 10 in you're manual. Than try booting. See if you're keyboard allows you to get into the bios/cmos. I'm guessing you tried another keyboard? You can also buy a PS2 - to -USB Y adapter. This is what one looks like.
http://www.cablestogo.com/product.asp?cat%5fid=104&sku=27225
If you bought an AGP graphics card lately you might have also received a single PS2 to USB adapter free. Like this one.
http://www.cablestogo.com/product.asp?cat%5fid=104&sku=35700
It's not uncommon for the the lights to function & yet the keyboard not function. A single pin within the PS2 on the keyboard could be bent or bad or not seating correctly in you're new board.
Mike
May 31, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Ati radeon 7000 agp card not recognize by the system
Have you tried cleaning the AGP slot out with a combo of canned air & a clean paint brush? Set the bios for AGP 4X & connect power to the 7200 if power is needed. Still nothing. Try another AGP card.
Jan 13, 2008 | ATI RADEON 7200 (64 MB) Graphic Card
Dell (E210882) Motherboard Logo
377 people viewed this question
Alun Cox
