Question about Dell UltraSharp 1907FP 19" LCD Monitor
My monitor keeps turning off every like 5 minutes and i dont know
Can someone help me? cause its annoyingg
  • 60 Answers
U have to check the power cable and data cable connect with cpu and monitor. if problem is not solve then go to control panel and trobleshoot the disply device ie; monitor
Posted on Mar 03, 2009
My HP Photosmart B110 Series wont scan to my PC. The window kept showing that its necessary to update LCD screen? I dont know what it meant and I dont know how? Please help!
1) Leave the computer on with Digital Imaging Monitor
2) Turn off the printer
3) Disconnect the USB cable
4) Wait for 3 minutes
5) Turn on the printer
6) Wait 3 minutes for computer to update the printer
Regards,
Shrey
May 30, 2011 | Office Equipment & Supplies
Mhat would cause scrolling lines on a benq monitor they are there even when it is not connected to a pc the benq screen comes up when power is turned on but it is pink with horizontal lines scrolling...
it sounds like you have some dead pixels in you monitor. i suggest if its still under warranty return it immediately because if not your going to have to buy another monitor if you can live the with lines there. hope this helps.
crm8
Mar 15, 2011 | BenQ Computers & Internet
I have a westinghouse monitor L1916hw and my monitor was fine last night but this morn when I woke up the lighting was flickering and then went black and when I turned it off and back on it will stay lit...
Get in the habbit of turning off LCD monitors when not in use. First, save electric. Second, save your monitor as LCD will burn up faster than a CRT. As for your problem, I would assume it's burning out and/or about to burn out...overheating. I would shut the entire system down, let is sit for 5 minutes and reboot everything. If it still fails to strike properly, it is probably toast.
Jun 29, 2010 | Westinghouse Electric L1916HW 19" Monitor
By tessadupre on Oct 03, 2009
im positive its the inverter board going bad
Oct 21, 2009 | E-Machines eMachines Monitor E15T4
My screen only displays after 4 /5 hrs
Try a different screensaver.
Also look in the display properties by simply right clicking the desktop and clicking properties.
Then locate power management.
the initial seems to be a bad screensaver judging by the 20 minutes, but the 4-5 hours seems to be a sleep mode that bypasses the screensaver issue.
Jul 23, 2009 | Computers & Internet
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Sceptre X9G Komodo IV 19" Monitor
Hi dgp1952, Check with www.lcdrepair.net if you want a repair. Something is wrong with your backlight or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. Dust can cause the circuitry to heat up faster and put the power supply into Clamp mode. Clamp mode will turn the supply off to certain circuits which may be the reason your display is going black after 5 minutes.
Oct 09, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Monitor turning off
If I understand you problem correctly, your monitor is turning off when it remains idle? Does it come back on when you use the keyboard or move the mouse? If so, then this could just be caused by the computer's power-save settings. This can be adjusted by right clicking on the the desktop and selecting propeties. Go to the screensaver tab and click on the power button. From here, you can either set the "Turn Off Monitor Time" to never, or to a greater period of time.
Oct 16, 2006 | Sylvania CL972B (Black) 19 in. Flat Panel...
Dell UltraSharp 1907FP 19" LCD Monitor Logo
140 people viewed this question
Alun Cox
