Question about Motorola Mobility RAZR V3i Cellular Phone
Speedial every tim i hit 1 on my speed dial it comes up wit a number and not voicmail how do i fix it
    Master:
  • 497 Answers
Hi
did u try constantly pressing the button down for a while without pressing the hash button
hope this wrks for u
Thanks for using Fixya
Have a nice day!
Posted on Mar 03, 2009
I can't remember how to assign a speedial #
Thanks for visiting FixYa!
Speed dial numbers are assigned when you first enter a name and phone number for someone in 'Contacts'. To edit the speed dial number, go to Contacts > (Select the Name of the person you want to change the speeddial # for) > select, Edit > and choose a speed dial number not already assigned. Remember Speeddial #1 is reserved for your voice mail.
If you need more specific directions, please submit another question and include the Make and Model number of your phone.
Apr 02, 2011 | Cell Phones
Dialing speedial 1 does not access my voiemail even tho it says it is dialing it a greeting comes on asking for an access code. the nly way to get voicemail is dialing manually and the icon onscreen does...
OK, usually one cannot use the speed dial feature unless you insert, pauses in the number, IE: you must add 1 second, "Pauses", after and before the number you dial... also you can then add, your access code too, well theoretically anyway..
So, you pause, for 1 sec, then dial the number, pause for 2 - 3, 4, maybe 5 seconds, seconds, then enter your access code and Enter code.
This should then be able you to then speed dial and connect and enter your PIN, all at the same time, if your PIN isn't recognized, try adding more pauses before entering.
If NONE of it works, then you simply have a network/phone that will not do it.
Aug 11, 2010 | Cell Phones
IntelliFax-4100e
go into menu, arrow over until you see 2. Fax hit set, then arrow until you see 1. one-touch speed dial, then hit set. touch the one-touch button you want to change, then the number 1 to change it, it will display the number, hit clear to delete it then dial the new number hit set and you're done.
Feb 11, 2010 | Brother IntelliFax-4100e Fax
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
Programming speed dial numbers into NEC DTU-32D-1A phone
hit feature key,hit a line key,dial 9 plus the number,hit feature
Mar 12, 2009 | NEC Electra Elite 32D-1 Corded Phone
How to change my speedial numbers?
basically the way i do it is, press the dial button with the numbers, then press down and number which doesnt have a speed dial already, and if you hold down it will say " no speed dial set " and then it will take you into the next bit :P
Jan 27, 2009 | LG KU990 Viewty
I work for the county and I have to dial a code # first
18001234567,1234567890,1234567890
program your speed dial with 'symbols(button)' between the groups of numbers,
the 'symbols' adds a 2second delay between the dialed characters at that point.
except for the first 'symbol' the first 'symbol' pauses till the other end answers the phone and handshaking has taken place.
If the numbers are not always the same, program two speed dials, one for the 1800, one for the password.
and when sending
speeddial1 number speeddial2
Jun 26, 2008 | HP PSC 950 All-In-One InkJet Printer
Voicmail options
Go to main menu, settings, call, send DTMF tones and select on. I had the same problem as you all and this fixed the problem for me :)
Jun 13, 2008 | LG Prada KE850 Cellular Phone
1 touch dialing
Okay hopefully by now you guys have figure it out but for other who haven't yet... in your list of contacts select and edit the contact you want in position #2 scroll down till you see speedial or the lighnting symbol.. thats where it is set up.
Nov 30, 2007 | Motorola Mobility RAZR V3m Cellular Phone
One touch dial or speed dialling.
Hi Menu => Contacts =>Speed dials. Good luck.
Aug 28, 2007 | Nokia 1100
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
