Question about Necchi 4595 Mechanical Sewing Machine
Pulling on top thread bunches my fabric
I can pull on the top thread and it bunches my fabric up. I'm pretty sure I shouldn't be able to do this. But I have no idea how to fix it... it seems like it should be a simple solution.
  • 323 Answers
Either the top tension is too tight or the lower tension is too loose.
sewman7
Posted on Apr 26, 2009
Thread is bunching up under my fabric as I sew. I have changed the top thread & bobbin several times, to no avail.
indicates that the top thread tension is not tight enough
as you pull the thread to thread the needle , there should be a resistance to pulling that thread or the tension is not high enough
Sep 13, 2017 | Sewing Machines
Thread bunching up on bottom of fabric
Remove the top thread from your machine (NOTE: ALWAYS clip the thread next to the spool, lift the presser foot, and gently pull the top thread down from top to bottom!!! This helps reduce the chances of breaking something by pulling the thread upwards!)
ALWAYS RAISE the presser foot and rethread the top thread from beginning. Verify the thread path is correct and start out with the thread tension set at the midway point (and then tweak the top thread tension through testing).
FWIW, if the thread problem appears under the fabric, it is generally a top thread issue. If the thread problem appears on the top of the fabric, it is generally a bobbin thread issue.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
CURED Sewing Thread Nests on the bottom
Jul 04, 2017 | Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
Thread jams when I sew.
Hi
Try changing the needle.
if not check your tension and make sure its not to slack
Jul 15, 2015 | Sewing Machines
The thread keeps breaking, bunching up under the fabric and when I zigzag the bobbin thread pulls up and shows on top.
need to rethread the bobbin and make sure it gets into the tensioner hold the bobbin and pull on the thread where it comes thru the presser plate
Mar 19, 2015 | Sewing Machines
Bobbin thread is bunched up when sewing straight stitch
If you're getting the bunching of thread on the bottom of your fabric, make sure that you have the machine threaded properly on top. If you pull the thread through the needle with the foot up, you feel little or no resistance. If you put the foot down, the thread should become harder to pull and the needle will bow. If this doesn't happen, the upper tension is not working correctly or is too loose.
Sep 30, 2011 | Husqvarna Viking 1
Hi, my thread gets caught and pulls the materal into the foot and i can not sew due to the jamming and the thread get all bunched up by the bobbin
I had similar problems when I first started sewing. Try adjusting the tension in your thread - less tension for lighter fabrics, more tension for heavier fabrics. This will stop the needle from pulling the threads in the fabric.
As for the thread getting bunched up in the bobbin - this is most likely because your bobbin is the wrong size for the machine, or that you did not thread the bobbin properly. Try re-threading, this time making sure you pull the thread into the bobbin container tightly. This should stop the bobbin from jumping around the container and spitting thread.
Feb 27, 2010 | Brother Sewing Machines
I have a Singer Sewing Machine 5817C, the thread bunches under the fabric while sewing. I have tried adjusting all the switches so that I just get a standard straight stitch, but it bunches up on the...
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
Oct 14, 2009 | Singer Sewing Machines
The tread gets all bunched up on the underside of
Take the thread off the top of your machine and rethread it. Anytime a sewing machine bunches up the thread on the bottom the cause is the top thread. Make sure the tension dial is on "5". After you thread the machine, put the pressure foot down,(like its resting on fabric, but not on the thread), and pull the thread towards the back of the machine. It should be somewhat tight. The needle should "bow" slightly before the thread comes through the needle.
Oct 06, 2009 | Sewing Machines
Bobbin thread gets bunched up and loud clicking sound
The problem is never the bobbin when you have this problem. It's the top thread. Take the thread off the top of the machine and rethread the top. Make sure the small tension dial is on 4 or 5 (the larger dial on the front left is for the pressure on the foot, not the thread tension.) After you thread the machine, put the pressure foot down but NOT on the thread. Then pull gently toward the back of the machine. When you do, the needle should bend slightly backwards before the thread comes through the machine. If it pulls with no resistance you could simply have "fluff" or remants of thread between your tension discs. If you do, put the dial on zero and using an old needle, clean between the discs and try threading the machine again with the "pull test" I described earlier.
No tension on the top of the machine, lets the bobbin tension win and it pulls all the thread to the bottom of the fabric.
Sep 20, 2009 | Husqvarna Lily 540 and 550
Necchi 4595 Mechanical Sewing Machine Logo
105 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
