Question about Microsoft Windows 98 Second Edition for PC
What are the settings for windows 98 for d-LINK DIR615 ROUTER
Can anyone tell me the settings to get a internet connection on windows 98 running off a dir615 D-link router. Tech support I talked to said they dont have tech support for windows 98. grrrrrrrrr. My other pc works on wireless and my other pc works fine on windows xp but dont know how to set up windows 98 on a 3rd pc. Thanks from todd
  • trbushby Mar 03, 2009
    yes it has a network card and was working fine before the new wirless router was hooked up. This pc is hard wired to the wireless router with a wire . I plan on using the wired connection on this pc with windows 98.
  • Rob
    Rob May 11, 2010
    Does The Win98 PC have a network card? If so, are the proper drivers loaded for it? Are you planning on using wireless or wired connection?
  • 5 Answers
In control panel, find the network applet and double click it. in the white box, locate TCP/IP(Internet Protocol) and select that, then click properties
Make sure you're set to DHCP which should, once you're physically connected to your router, obtain an IP address and DNS server addresses automatically
Posted on Mar 04, 2009
My internet supplier is telling me that I am at risk unless I disable the UPnP on my DLink model Dir615 router. I searched and found a video that indicated how to do this. Within the video it shows me...
Assuming you are using a web browser to access the settings, please try a different browser. I hope it is that easy for you.
Otherwise I would suggest getting in touch with DLink and checking if there is a firmware update that addresses this.
Dec 26, 2014 | D-Link Dlink Wireless N 300 Router Dir615...
I cannot reset my d link dir615 wireless router, can anyone help
First, to reset the router to factory default setting, press and hold the reset button for few seconds (It is at the back of the router near the DC Power Jack). The LEDs will then blink and the routers factory settings wouls be restored.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 29, 2010 | D-Link DIR-615 Wireless Router
Intermittent wireless Internet access
The problem started after you added the additional devices. Now you probably have all of your devices using DHCP which means the router provides an IP Address for your devices. Change the devices to have a fixed ip address. You may have to check the router for the default internal ip address, but it is probably 192.168.1.1 as the gateway. With the PC and laptop go to the control panel, then network connections, right clip on the connection and select properties, then scoll down the window until you see tcp/ip connection, select properties from the tab options below and set the ip address of each machine to 192.168.1.10, 192.168.1.11 and 192.168.1.12. set the gateway to 192.168.1.1 and set the dns ip to 192.168.1.1. Now if you have a different gateway address, use that as applied above. Save the settings and retry your connections.
Here is way you are probably having problems, wireless networks will drop and reconnect more often than a cable connection. If you were using just a cable connection, there would be less of a problem. When DHCP is being used and a computer drops the connection, it could get a totally different ip assignment the next time (a matter of less than a second of time). When that happens the original connection is lost. By fixing the ip address to be static, any time you reconnect via wireless, it uses exactly the same address, thus maintaining the connection.
Try it out and leave feedback if it works for you, otherwise send me the results of the test.
Feb 02, 2010 | D-Link DI 514 Wireless Router (DI-514)
Cannot connect my laptop to internet through router wrt54g v8
Make sure you have ipx and spx protocol installed, and a home network setup through windows. Also if the first try don't work make sure you firewall setting is not blocking your router.
Dec 03, 2009 | Linksys Wireless-G WRT54G Router
We have aa dlink DIR615 router. Can you tell me
This button is used to quickly set up wireless networks with the WiFi Protected Setup.
Wi-Fi Protected Setup is used to easily add devices to a network using a PIN or button press. Devices must support Wi-Fi Protected Setup in order to be configured by this method
more information is available in your manual and this forum
If this helped you then please help me and vote kindly, thank you.
Oct 11, 2009 | D-Link (DI-711) Router
Wireless laptops and desktop pc show status connected to the router but neither connect to internet
take the internet connection from the back of your router and plug it in to one of your pc's. try logging into the internet. this will tell you if the network is available to the router- if it is-
go to wireless pc
go to run , type cmd
in black window type ipconfig/all hit enter
the ip of your router will be displayed.
go to your browser, type in the router address where you usually put a web site name. hit enter
a window should appear asking for login and password to the router. if you could get to the internet on the cable and can't from the router the router is not set up properly and you must log into the router and set up the way it talks to the internet.
Sep 09, 2009 | Computers & Internet
Connecting to Netflix with a Roku video player
What is the exact error message??
Are you unable to connect to LAN or Internet Or Wireless network
May 31, 2009 | D-Link DIR-625 (790069292637) Wireless...
Having problem installing my dlink dir615 router
First, is the problem truly that you can't get an IP address from the router or is it that you can't get on the internet. I will touch base with both issues briefly. Many newly placed routers need the MAC address cloned within the router setup to register with the ISP and recieve internet access. If the PC is truely not recieving an IP from the router, make sure DHCP is turned on and set a range of address you wish use. Tip: limit the number of addresses to only what you will actually use. Make sure your computer is set to recieve an IP automatically and you have the proper client, service and protocols running. Basically, If the PC will run directly from the cable modem, then it should run from the router also. If the PC will not obtain an address from the modem directly then your winsocket may be corrupt. Malware will often do this. It is easily repaired and there are many winsock32 repair tools on the net. Just Google "winsock repair" without the quotes and you will find a multitude of software.
Jan 17, 2009 | D-Link Computers & Internet
No connection to internet
What version of windows are you running? 98, 2000, XP, Vista?
Nov 15, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Microsoft Windows 98 Second Edition for PC Logo
136 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
