Question about Emerson Black Microwave Oven
No light inside of microwave
Nolight inside when door is open or while it is running
  • 463 Answers
I hape that's .9 cubic feet, cause it it is 9 cubic feet that is on heckuva microwave!!!. Anyways, did the light once work? or are you curious if it supposed to have a light. If the light once worked, replace the bulb...
Posted on Mar 03, 2009
Microwave keeps running with door open
I'd say the door interlock switch has failed, and supplies a connection when it should not. Microwave ovens can be dangerous to anyone poking around inside, even when unplugged, so get a quote from a service tech. You might find that parts+labour is almost as much as a new one.
Microwave radiation being released through an open door is also a hazard, as it is known to cause eye cataracts, so don't get near if the oven does this.
Nov 19, 2013 | Panasonic Inverter Countertop Microwave
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
My JE 1860 microwave starts working when I open the door.
It sounds like the door switch is bad. It may be that the switch is shorted inside. I would think it may really run with the door open, and microwave you.
Mar 06, 2010 | GE JE1860 Microwave Oven
Plugged in, nothing works
have you checked the fuse inside the unit?
Jun 19, 2009 | Emerson MW8777W Microwave Oven
Light Not working
The following is generic to most microwave ovens for the light:
Inside all microwave ovens there are sensor and safety switches that work with the door. There are also some electronics on the controler board or a daughter board that control the light. The fault would most likely be in those areas. Some models have a door switch that is specificaly for the light.
The service tech would start by testing all the sensor and safety switches. If these, the wireing, and the connectors are all okay, he would then verify the operation of the circuits for the light.
Jerry G.
Jun 16, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Light not working
Check around the perimeter of the door housing for a switch that might be stuck in the open position.
May 29, 2008 | Emerson MW8987B/W Microwave Oven
Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Dec 18, 2007 | Sharp R-1470 Microwave Oven
Microwave works with door open
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
Nov 07, 2006 | LG LRMM1430 Microwave Oven
Emerson Black Microwave Oven Logo
306 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
