Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage Door Wont Close Craftsman 1/2 HP (1998)
Replaced the gear and sprocket assembly as they were stripped. After connecting everything back together the hard wired panel button worked to open and close door. When I left a day later and tried to use remote it would start to go down about a foot and then reverse itself. Had to hold wall button down to close. Next day same problem wall button opened but remote wouldn't close, and this time holding wall button down took a few tries, sometimes it would get about 1/2 way down and then reverse while holding the button. Finally, third day wall button opened but remote wouldn't close and now wall button wont close. Sensors are aligned and lights are bright green and light responds when beam is broke. Increased the force but that didn't do anything. Light bulb does not flash and click like sensors think something is in way. Amber light on back flashes 5 times. Please help.
  • Anonymous Mar 03, 2009
    same
  • 8,197 Answers
What it is is the electric beams at the door are getting blinded buy the sun or out of line. They are the two black boxes on both sides of the door about a foot from the ground. Put a piece of card board in front of them not blocking the beam dut to block the sun. All that they are is safety beams for kids so they do not get hurt. If you have to move them to the top where the sun will not hit them. Sorry to say though you can not remove them all the way. Also make sure the lite on them is not blinking if so they are out of line.
Good Luck and Please Rate FixYa!
Posted on Mar 05, 2009
    Problem Solver:
  • 9 Answers
I replaced the worm gear and put the opener back up and now the trolley will only travel about 6" no matter how I adjust the travel or force. The light sensors are aligned and light up green. The opener has the green light on the back of it and it flashes 2 times quickly every 6 seconds. None of the remotes open the door either, HELP
Posted on Nov 19, 2009
Why wont the replaced liftmaster sprocket turn clockwise after replacement?
Looking down at the sprocket. When it turns clockwise it is closing the door and when it turns counterclockwise it will be opening the door.
Jul 01, 2012 | Sears Craftsman LiftMaster Chamberlain...
How do I tighten sagging garage door chain?
I think you have more problems than just a sagging chain. It is most likely sagging because the bronze bushing at the gear and sprocket assembly is bad. It lets the sprocket lean forward and loosens the chain. You will also need to remove the cover from the motor unit and check the drive gear. It is a white gear just in front of the motor and is most likely stripped.
Jul 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
I replaced the sprocket and gear assembly on my
Here are some things to check.
Loosen the chain enough so that you can remove it from the sprocket above the motor unit. With the door closed run the motor until the sprocket turns clockwise and stops. With everything attached replace and tighten the chain. Some adjusting of the up and down limits will probably be required.
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Jan 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't open or close door
The drive gear is stripped. Remove the cover and you can see it just in front of the motor. It is white nylon and the part number is 41A2817. Available from Sears or any good door opener service company. It will come with instructions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1\2 hp clicks, motor wurrs for 1 sec', but doesn't open
You have a stripped gear on the opener. Take off the cover on the motor. The bottom of the cover will be filled with white shavings. You can repair this with a "liftmaster gear and sprocket assembly".
Feb 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor doesn't work.
2 flashes is a safety eye issue, but you problen is most likely that the chain is not sync with the limit setting. Take the bottom off the gear and sprocket assemble and rotate center limit srew until it is in the same position as the trolley.
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opener will not opern
2 flashes indicate safety eye issue. Check you wiring and make sure it is wired correctly and check to make sure the eyes are properly aligned.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
How is the chain supposed to be aligned
sync the motor. the gear kit tells you how. get motor up and position trolley near motor, assuming you left chain/cable attached to trolley). Get motor up by running motor and then pushing button again. if motor reverse, let it run and it will stop in up position.
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Sprocket replacement procedure
You need a gear kit. Amazon sells them. I got mine at a Sears Service center. Beware that you will need to completely disassemble your unit to replace the gears.
http://www.amazon.com/Sears-Craftsman-Liftmaster-Garage-Opener/dp/B000JGLX9C
Mar 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
587 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
