Question about GE Nautilus 24" Built-in Dishwasher
Detergent cap the detergent cap will not stay closed, doesn't click closed as use to..
  • 4 more comments
  • marsha_lavin Mar 03, 2009
    the model number may be inside, but i have it running, with the broken cap, just was filled so see what happens... its a 6year old nautilus, white dishwasher.. is the model number inside? the cap that closes the detergent holder won't close and stay closed, it slips back open with no tension to hold closed... thanks
    Hope one of these is it:
    GSD4200J00WW
    serial.. VG7488338
    also a number 40225
    thank you, its fixed
  • scottstrickl Mar 19, 2009
    I have the same problem.
    Model GSD530T60WW
    SN TL7765225
    I took the cover off and I can not understand what holds the soap door shut?
    Also the three armed dark plastic (GE Part number 828 in the parts manual) looks like it might have a small piece broken off the hub.
    Thanks
    Scott
  • Affordable Appliance Parts
    The model number is located in the frame where the door closes against. Perhpas later you will hav etime to open the dishwasher and get this information for me. I need to see how your detergent dispenser latches and I can only do this with the model number....
    Eric Campion
    Please supply the complete model number for your unit and I will take a look and instruct fruther.
    Waiting to hear from you, Eric Campion
    Novelist:
  • 117 Answers
Thanks for the model number. On your particular unit you can only latch the unit in the off position. If it still does not latch, open the door and remove all thr screws you see. Normal seven of them. Now, split the door and take a close look at the locking mechanism. Did something come loose? Is the spring in tact...Play with it and see how it works,...then what must be done to repair. It is really a simple system and has been tried and tested for many years in the GE Dishwashing Units. Good Luck, Eric Campion
Posted on Mar 03, 2009
How do I fix the soap dispenser cap
Chances are the plastic catch broke or wore off. If that's the case, you have to replace the entire soap dispenser.
Sep 14, 2014 | GE Nautilus 24" Built-in Dishwasher
Detergent dispenser not closing
split the door inner from the outer - screws round the periphery. you will need a multimeter check if there is a supply to the detergent dispenser when there should not be ie during rinse and hold program or before starting the cycle. if there is a supply then the module is faulty. if not then fault probably lies with the dispenser itself. having split the door you can see how to remove. there are two methods of fixing. most common is six screws holding clamps. some are a push and click fit
Jun 03, 2007 | Bosch SHU5316UC Dishwasher
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
Soap not dissolving in dishwasher. stays in compartment
Hi, dishwasher detergent stays in the compartment because Bosch has designed a gap at the top of the compartment that feeds water onto the detergent before the cover opens. This has possibly been done to soften up deteregent tablets and help them dissolve.
The result is a solidified mass of wet detergent that doesn't come out of the compartment when it opens, and slowly dissolves onto the dishes leaving them coated with alkaline detergent at the end of the cycle. The residual lump of detergent is in the compartment or on the bottom of the dishwasher (refer photo).
The solution is to remove the compartment cover and look for the small gap at the top of the compartment as in the photos. Clean the surface and fill the gap with epoxy glue. This will keep the detergent dry until the cover opens, allowing the detergent to fall freely out of the compartment._1583.jpg
Jun 23, 2010 | Dishwashers
Light on my dashboard
ford taurus's are well known for this. the seal on the gas cap goes bad. before you replace the gas cap make sure when you close the gas cap you are turning it at least 5 clicks. if light stays on get a new gas cap. they are easy to install all you need to do is remove the gas cap.remove the gas cap strap. put ******** the new cap, close cap and turn 5 clicks. not clicking 5 time can set a p400 or p401 evap code causing the check enging /ses light to come on.
Apr 19, 2009 | Ford Taurus Cars & Trucks
Dishwasher detergent door.
No short of replacing hte dispensore assemby, chances are the plastice catch has broken off, and is not repairable, sold only as complete assembly
Jan 01, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Need a diagram for the kenmore dishwasher model 665.16645890
I have GE Dishwasher (model no:GSD1100G02),and for the last few month I was not able close the main detergent cup cap(it is coming back to full open position,even after keeping the CAP turned all the way to a closing postion)
I have called the GE spare parts division,and obtained the New detergent cup cap,and when I tried to remove the old one,inorder to replace with the new one,I was not able remove old one.
Please help me how to remove the old main detergent cup cap,and replace with a new one.
Hope I will hear from you soon in this regard.
Murthy Pillutla
Home Ph:630-428-3277
Cell:484-919-3653
Jun 14, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
GE Nautilus 24" Built-in Dishwasher Logo
495 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
