Question about Refrigerators
I purshased a kenmore refrig to send to middle east
Will my kenmore work in the middle east considering the cycle of the motor...
  • 1 more comment
  • kigbillhassa Mar 03, 2009
    their voltage is 220 volts wich i can get a convertor for that,but how can i convert the 60 to 50 hertz.??
    220 v 50 hertz..
    HI, WHAT SHOULD I DO IF THEIRS IS 220V 50 HERTZ/CYCLE
    Novelist:
  • 117 Answers
What is their voltage, hertz? American made products are 110 volts 60 hertz/cycles. If voltage their is different, you may be able to find a converter......Just don't go plugging it in until you have all the information at hand. If I can help further, I am here....Eric Campion
Posted on Mar 03, 2009
  • Affordable Appliance Parts
    I think I would email someone you know in that country and see what they do in the instance. Once you know this, you can check pricing and perhaps purchase the needed items prior to shipping the unit and put the converter inisde. I am really not that familiar with other country voltages......The net has lots of solutions. Good Luck, Eric
Kenmore side by side 253.52349302 making stalling noise
motors start capacitor relay may be going bad..
Jan 20, 2014 | Kenmore Refrigerators
Kenmore 80 series washer cycle issue
motor coupler is most likely broken. remove cabinet, remove pump from motor, then remove motor from gearcase. the coupler can be purchased at local parts supplier or ordered on line.
Jan 30, 2012 | Kenmore Washing Machines
Kenmore Sideby side refrig 106.53242300 freezer
sounds like a bad blower motor . replace it . the brg must be bad . mm
Feb 04, 2010 | Kenmore 52342 / 52344 / 52349 Side by Side...
Washer will fill up with water and that's it. Will not go into agitate or spin cycle. Did some loads this morning. Was going to do one more and found machine in middle of spin cycle not working. Tried...
If Kenmore and direct drive with no belt
then motor coupling needs to be replaced
The coupling is what is inbetween the motor and the transmission. It consists of 2 plastic pcs and a middle rubber. The purpose of the coupling is to not only interconnect the motor to the transmission therefore eliminating the BELT BUT if the washer is OVERLOADED, this inexpecnsive coupling breaks before other damage to motor or transmiossion occur.
Nov 20, 2009 | Kenmore Washing Machines
The water want drain so the spin cycle can start
You either have a bad pump or one direction of your motor is bad. Kenmore washers are direct drive machines. The motor turns one way to wash and the other to pump and spin. The pump is east to replace after you remove the case. If you would like to remove it so that you can find what is wrong, reply back and I'll walk you through it.
Please rate solution
Sep 14, 2009 | Kenmore Washing Machines
Kenmore Fabric Care 90 won't stop washing
It sounds like your timer motor may have died. Pull the knobs off the controls and remove the screws in the control panel to get to the motor. The motor is usually pretty expensive, so you might want to consider buying a new washer over replacing the timer motor.
Apr 18, 2009 | Kenmore 22422 Top Load Washer
Kenmore HE3 stops in middle of cycle, flashes F-11.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Machine won't work. kenmore 90 series
Might be a broken motor or a blown fuse. I would suggest having your machine looked at by a specialist. If it's old, you might consider replacing it.
Mar 21, 2006 | Kenmore 15864/15862 Top Load Washer
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
