Question about Ricoh Aficio CL3500N Laser Printer
SC 441 Alert, Richo Aficio CL 3500N
Everything was going well, and then this printer stoped printing. An alert came up: SC 441.
I think I have read that this may be fixed, by reinstalling the softwere
I have run into this several times with these printers. In every case, it has been the CMY PCU. These run about $300.
I have read that by cleaning the PCU, you can get it to work sometimes. So far, I have not been lucky enough for it to work.
Posted on Apr 14, 2009
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
How can I correct error SC559?
Fusing Unit Third Jam Error (Fatal Error)
The exit sensor failed to detect the leading edge of the paper within the prescribed time and triggered a jam alert.
  • ? Afterthiserrorhasoccurredthreetimes,themachinewill shut down automatically and cannot be re-started until the machine has been serviced by a service technician.
  • ? Checkthepapertransportpathforanyphysicalobstructions (paper scraps, etc.)
  • ? Makesurethefusingunithasbeeninstalledcorrectly
  • ? Afterservicingthemachinetosolvetheproblem,theservice technician must execute a "Fuser SC Reset". Otherwise, the
    machine will continue to issue this SC code and cannot be operated. ( "Executing Fuser SC Reset")
Feb 19, 2016 | Ricoh Aficio SP 100SF e Laser...
After replacing the main motor of my richo afico 2018 the copy result reduces is the cause of mismatch main motor?
Yes, If you have installed a main motor from Aficio 1015 the machine will work and there will be no SC Code displayed, but the machine will print a reduced image.
The part number for the main motor for Aficio 2015 is :
" AX06 0270 Brushless Motor 24V/20W "
Oct 05, 2013 | Ricoh Aficio 2015 Copier
When I turn the printer on all of the alert lights go on.
check the lcd screen of the machine if there is an error code like SC 542. with this machine it will always show what is the problem through CODEs.
Apr 23, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
Repair error 441 in cl3500dn printer
SC 441 - development motor lock.Possible causes:
too much load on the drive mechanism
development motor defective
poor drum motor connector connection
interface board defective
Feb 03, 2013 | Ricoh Aficio CL3500N Laser Printer
My printer flashes alert CS 441 off on. Can you tell me what's wrong?
The SC 441 is a color pcu motor lock. One of the waste toner augers is clogged with waste toner not letting the drum turn. The only real fix is to replace the color pcu unit. If you could get the auger and drum out it might be possible to free it up, but you will probably damage the drum in the process.
Apr 15, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
http://www.websitetoolbox.com/mb/copierquestions
Jan 19, 2009 | Ricoh Aficio CL3500N Laser Printer
SC 441 Error code
Transfer belt cleaning unit.
open top cover, cleaning unit cover(2 black tabs rear)
pull unit slowly. check if paper jam or gears not turning
Dec 24, 2008 | Ricoh CL1000N Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
1,177 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
