Question about Kenmore Washing Machines
I have a kenmore 20702 top load washer. Sometimes
I have a kenmore 20702 top load washer. Sometimes the washer stops after the wash cycle when it should drain but does not and after a short pause then it will start to drain while the tub starts to spin. Sometimes it will also try to engage the motor to drain the tub but as the transmission clunks when it would normally drain, it just stops and then continues to the spin cycle. It has also totally skipped through the rinse cycle and continued to agitate to the next cycle. This is a wierd one. Any help would be appreciated. Thanks in advance, Shane.
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Not doing anything, making a ratchetting sound, won't wash, spin,rinse, anything
Have you checked the drum for residue that may actually prevent it to spin? try to check the cycle selector as well and try to load more clothes... keep us posted, thanks for using fixya!!
Jun 03, 2008 | Kenmore 24032\24036 Top Load Washer
It turns on and fills by itself. sometimes it
a bad water valve could cause this / if it leaking through . when the tub is full it will start itself and cycle . / also the control if bad would do this .. mm
Dec 03, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 70 series 20702 will not spin or drain
it sounds like your coupler is broken, with the machine unplugged and with help pull the washer out and then tilt it back. look between the motor and the transmition for a back disk sandwiched between 2 white disks. if it is gone then you need to replace the coupler. it is a medium difficulty job, you need to take the shell off in order to do the job.
Dec 17, 2008 | Kenmore 24032\24036 Top Load Washer
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
78 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
