The code to program my remote control for my tv Prima PH 42R6C''
I need to know the code to program a new universal remote tv for my PRIMA PH-42R6C. I don't find the code and i don't know what kinf remote i need for this tv.
The problem is i lose the remote
Thank's for your help
yvon.rathe@sympatico.ca
Posted on Mar 03, 2009
I can't find a remote for my Prima TV model#XT-2799. Help!!
Universal remote codes for Prima TV are:
1019 0165 0116 0167
Just note these codes, and buy a universal remote control, which have these setup codes in its code list.
If your TV asks for a five digit code, buy one RCA RCR 311STN model remote control. Five digit codes for this remote control, with Prima tV are:
10761, 10783, 10815, 10817
Jun 13, 2012 | Prima CV2011 TV
3.4 IR Dish Network remote control codes for a Prima TV/DVD combo. I can't seem to find any codes that work for either.
I'msorry I did also attempt to locate a Prima remote code within DISH Network's database aswell but unfortunately I was unsuccessful and have found no remote codesfor the TV you have. However, we can still attempt to program the DISH Networkremote to the Prima television without a remote code, this would be done bycompleting a Power scan. If you decide you would like to program the DISHNetwork remote to your TV using the power scan, I have included instructionsbelow to further assist you. Withthe desired equipment on, press and hold the correct Mode button (In this casethe mode button will be "TV") until all the other mode button back lightsilluminate, then release. 1. Pressand release the Power button. 2. Pressthe Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, theequipment will power off. 3. Pressthe POUND (#) button. If the codeentered is valid for the remote, the mode light flashes three times.
After successfully completing the power scan to program the DISHNetwork remote to your T.V the remote should now control your TV. I hopethis helped! Please feel free to let me know if you have any other questions orneed additional help. -Kirstie DISHNetwork
Jan 30, 2011 | DISH Network IR Remote Control
I am having problems programing a universal remote control, I can't find codes for PRIMA TV
urc-386-remote.blogspot com
URC-386 HRS-GLOBAL
URC-386 Universal Remote Control
http://urc-386-remote.blogspot.com
Jan 19, 2010 | Prima C2012 TV
I want to program my dish network remote to my prima tv
Hi my nameis Mike Houston of DISH Network. I see you are looking for the remote code toyour Prima TV, we do not have the three digit code at this time but we have away to program the remote to the TV through a Power Scan. I will send you thelink that will help with these steps, http://www.dishnetwork.com/SupportSection/power-scan-instructions.
Jan 03, 2010 | Prima C2012 TV
I need 3 digit code for my Prima tv to program bell express vu
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Dec 16, 2009 | Prima C2012 TV
Need help to program my new T.V. to my remote
hold down code until it stays lit, then press tv then keep hitting channel up or channel down (either one can be used, keep pressing channel button til tv changes channels when it does press enter, or ok if enter is not there, it may take awhile maybe a few channel pushes up to 200 and up times, you use this method when you don't know the code for your tv. Hope this helps.
Nov 30, 2009 | RCA D770 Remote Control
I have an rca rcr311w universal remote and a prima tv..what is the code to program this
The listing I have shows these codes:
0047, 0054, 0060, 0039, 0051, 0154, 0016, 0030, 0056, 0451 for a Prima TV.
If your remote only requires three digits, drop the zero. Hope this helps you.
Oct 27, 2009 | Universal Remote Control DIRECTV Universal...
Can't get the remote to work
Try pressing the TV button on the Prima remote to make it work on the TV. It should work on the Prima Tv without new codes. Codes would be needed for your cable box.
Consider calling Prima at 866-447-7462 for the codes. They should have a website for the codes or email you the codes for free.
PS Please rate me if this helps.
Mar 30, 2008 | Televison & Video
Prima TV codes for using other remote control
I need codes PRIMA LCD modelo L3217
Jan 22, 2008 | Prima C2012 TV
Programming (JR800C) universal 8 Jenson remote controller
Google for the Jenson website, the chances are you will be able to download the manual for this remote.
Oct 06, 2007 | Televison & Video
Televison & Video Logo
243 people viewed this question
Top Televison & Video Experts
