Question about Mitsubishi WT-46805 46" Rear Projection Television
Covergence out of alignment on 1/4 Vertical left side of screen
The left side of the Screen has a bad ghost in Vertical Area top to bottom. If words are shown, there are Green and Red ghost lines.
It looks like an alaignment problem....Is this an easy fix I can do?
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Posted on Jun 13, 2009
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Screen not aligned
Ref. HP ipaq hx4700: "Align screen" after hard reset or battery loss. I know others have had trouble getting past the "align screen" setup; I saw a suggestion somewhere that said the points were registered incorrectly (maybe in some, but not all of this model?); and they had to tap at locations other than the center of the cross symbol. I tried a variety of combinations, and found that if I tap ABOVE the center (but still on the vertical centerline) for the middle, top left and top right locations; and tap BELOW the center (but still on the vertical centerline) for the bottom left and bottom right...it worked. That brought me to the "Stylus" setup screen...which I also became "stuck" on. So far, I haven't found a solution to THAT issue yet. Gee, why can't they make these things simpler?
Feb 13, 2012 | Computers & Internet
Align screen problem
Sep 21, 2011 | HP iPAQ HX4700 Pocket PC
My Viewsonic PJ860 projector (aka Hitachi CP-S860W) has developed a condition in which there is a yellow vertical stripe down the right edge of the screen and a blue vertical stripe down the left side of...
It does sound like this is an alignment problem of the blue LCD or a problem on the main board controlling it. I am not sure if this is a field adjustable unit. A call to the authorized service center should provide that answer.
Aug 11, 2010 | Hitachi CP860960LAMP Projector Lamp for...
Color is out of balance on bottom half of screen
This tv have covergence problems,it dead.The convergence board the 2 STK covergence ICS and some or all it resistors are dead.Must replaced these parts to solved convergence problems.The shop will cost u $300-350 for parts and labors.
May 23, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
THE PICTURE IS GHOSTING AT THE TOP & BOTTOM OF THE SCREEN. THERE
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 28, 2009 | Hitachi 46F500 46" Rear Projection...
Wavy and ghosting
  1. words at top left corner have same word under it in red also on bottom of screen have seen were changing ic;s part# stk392-110 will solve problem if so what are ic;s
Apr 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
I have have this TV for almost 3 yrs..now have a shaded area on the left side
The dark side of the screen causes of the lamp alignment or prism glass alignment. This is critical you have to consult your LG technician to do this. But if you have any background o repair consult the service manual. Please careful not to touch the prism quarts so that you maintained the clarity of picture and brightness on the screen.
Aug 27, 2007 | LG RU-52SZ51D 52" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
217 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
